VIABLUE EPC-2 T8 DOWN Phono Cable DIN 5 Pin SME Angled to RCA with Ground Wire 1.5m Cobra
The Viablue EPC-2 is an angled 5-pin DIN (SME) to RCA phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features a multi-conductor architecture made of tinned OFC copper, combined with a capacitance of 60pF/m on the signal side, to ensure electrical performance compatible with phono inputs while providing stable signal transmission. The DIN connector also allows for the separation of channels and grounds right from the source.
Reference : 21881
499,00 €tax incl.
415,83 € tax excl.
Viablue EPC-2 T8 DOWN Phono Cable DIN 5 Pin SME Angled to RCA with OFC Copper Ground Wire 1.5m Cobra
Photo of the Viablue EPC-2 T8 Cobra cable
The Viablue EPC-2 is an angled 5-pin DIN (SME) to RCA phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features a multi-conductor architecture made of tin-plated OFC copper, combined with a capacitance of 60pF/m on the signal side, to ensure electrical performance compatible with phono inputs while providing stable signal transmission. The DIN connector also allows for the separation of channels and grounds right from the source.
Designed for phono setups, it combines continuous shielding with a dedicated ground connection, minimizing the impact of external interference while ensuring that the ground connection is independent of the audio signal. This design allows it to integrate seamlessly into an analog system while maintaining signal integrity between the tonearm and the phono stage.
Viablue EPC-2: Conductor Architecture and signal stability
The design, which features three separate EPC-2 cables, organizes the transmission of the signal and ground currents, thereby minimizing internal interactions while ensuring uniform conduction along the entire length of the cable. This design utilizes tin-plated OFC copper conductors, whose cross-sectional area contributes to the stability of the signal transfer, particularly with regard to low-level variations originating from the turntable.
The 60pF/m capacitance on the conductor side, supplemented by 130pF/m for the shielding, directly controls the interaction with the preamplifier’s input, preventing excessive loading that could degrade the high-frequency response. This approach is extended by a double shielding system combining a conductive spiral and an silver-plated ALU-PET foil, maintaining continuous protection against interference, while the dedicated ground wire ensures the dissipation of stray currents without interacting with the audio signal. Together, these features preserve signal integrity in sensitive phono setups.
Image showing the 5-pin DIN connector on the VIABLUE EPC-2 cable
Diagram of the Viablue EPC-2 Cable Construction
Diagram showing the different layers that make up the VIABLUE EPC-2 cable
1Soft cable sheath
2Banding, fleece
3Spiral shield, silvered OFC strands
4Foil shield, ALU PET silver
5Inner conductor, tinned OFC strands
6Soft filler
Product typePhono cable
Length1.5m
Connectors1x Angled 5-pin DIN
2x RCA
1x Ground wire
Cable conductor materialTinned OFC copper
Conductor capacitance60pF/m
Shield capacitance130pF/m
Section0.326mm² (22AWG)
ColorCobra (black, yellow, and white)
PackageSold individually
Length (m)1.5
ShieldingYes
Section (mm²)0.326
ConnectorRCA
ConnectorDIN
Conductors Plating (Cable)Tin
VIABLUE EPC-2 T8 DOWN Phono Cable DIN 5 Pin SME Angled to RCA with Ground Wire OFC Copper 1.5m Cobra
The Viablue EPC-2 is an angled 5-pin DIN (SME) to RCA phono cable designed to transmit very low-level analogue signals between a turntable and a...
