![]() | twinned, high-end ![]() SOMMER CABLE - SC-ORBIT 240 MKII Hear pushing the grass ... would be possible with SC-ORBIT. If you value a natural sound, dynamic and high fidelity, choose SC-ORBIT. The loudspeaker is at the end of the circuit, and the feedback meansthe transmission of music are also of enormous importance. You already have a quality loudspeaker: the cable must also fulfill all requirements - and the result is remarkable! This is why we have created this superior quality in the elegant design, because the drivers are often visibly placed - and to facilitate the discreet installation we made them as flat as possible. The very short torsion of the strands of the core provides an improvement in the surface of the conductive braids, ensuring a remarkable purity of reproduction of the acute sounds. The two conductors being twisted in opposite directions, the cable always resumes its initial shape even after complicated entanglements.
Specifications: | |
Envelope, outside diameter | PVC 12 x 5.9 mm |
AWG | 11 |
Number of Conductors | 2 x 4.0 mm2 |
Copper strands per core | 1036 x 0.07 mm |
Operating temperature | min. -30 ° C |
Operating temperature | max. 70 ° C |
resistanto the fire by m | 0.21 kWh |
Weight per m | 121 g |
Packaging, packaging unit | roll 100 m |
Packaging, packaging unit | crown 25 m |
Color | Transparent |
Type | 2 x 4.0 mm 2 |
Electrical Specifications: | |
Capacity metric cond./cond. | <55 pF |
style = "font-size: small;"> | <4.5 Ohm |
Resistance, insulation | > 10 MOhm |
Diameter (mm) | 5.9 |
Length (m) | Sold by length |
Number of conductors | 2 |
Insulation material | PVC |
Shielding | No |
Section (mm²) | 4.00 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | No |
Average votes 4.7 / 5 22 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Franck M.
joffrey J.
joffrey J.
Olivier M.
Noel C.
