with our speaker cable, so flat that it becomes imperceptible once placed. It is ideal for laying under carpets, ornamental rods, ceilings and under furniture. The SC-TRIBUN is almost invisible and even a mouse would not notice it, because it is delivered only in white and without marking. It is therefore ideal for building installations (hotels, bars, sports halls) or in churches.
To rmark that the edges are beveled in such a way that it is practically impossible to stumble on the cable with the shoes or the rolling carriages. The wide, flat back is pre-treated to allow attachment to any location using double-sided adhesive tape.
Thes conductors of the SC-TRIBUN are easily separable, the cable thickness does not exceed 2 mm!
ADVANTAGES :
USE:
Specifications: | |
Envelope, outside diameter | PVC 12.8 x 2.4 mm |
AWG | 15 |
Number of Conductors | 2 x 1.5 mm2 |
Copper strands per core | 47 x 4 x 0.10 mm |
Operating temperature | min. -30 ° C |
Operating temperature | max. 70 ° C |
Weight per m | 53 g |
Packaging unit, packing unit | per meter |
White | |
Electrical Specifications : | |
Capacity metric cond./cond. | <60 pF |
Odometer Resistance, Conductor | 13.3 Ohm |
Resistance, insulation | > 20 MOhm |
