This 3m OFC hybrid cable has been specially designed for HE helmets. It is therefore intended to replace the basic cables supplied with these headphones. The cable uses silver-plated multi-stranded OFC copper conductors for maximum conductivity. OFC Copper (Oxygen Free Copper) provides increased signal accuracy and performance.
Hybrid Cable Jack 3.5mm to Jack 2.5mm for HIFIMAN Headphones HE Series OFC Copper 3m
This 3m OFC hybrid cable has been specially designed for HE helmets. It is therefore intended to replace the basic cables supplied with these headphones. The cable uses silver-plated multi-stranded OFC copper conductors for maximum conductivity. OFC Copper (Oxygen Free Copper) provides increased signal accuracy and performance. The new 2.5mm TRS Jack connectors make it easy to insert and remove the cable from the headphones.
| Specifications | |
| Product type | Jack cable |
| Length | 3m |
| Connectors | 1x Jack 3.5mm 2x Jack 2.5mm |
| Cable conductors | Silver plated OFC Copper |
| Connectors plating | Gold |
| Sheath | Nylon |
| General | |
| Color | Black and white |
| Length (m) | 3.0 |
| Section (mm²) | N/A |
| Connector | Jack 3.5mm |
| Connector | Jack 2.5mm |
