VIABLUE EPC-4 T8 STEREO SMALL Jack 3.5mm Cable 50cm Black
The Viablue EPC-4 T8 Stereo Small is a stereo Jack 3.5mm to Jack 3.5mm cable. It uses tinned OFC copper conductors and features a capacitance of 45pF/m, for an outer diameter of 5mm, sheath included.
Reference : 22339
124,90 €tax incl.
104,08 € tax excl.
Viablue EPC-4 T8 Stereo Small Stereo Male Jack 3.5mm Cable 50cm Black
Photo du VIABLUE EPC-4 T8 Cable for Earphones Jack 3.5mm Stereo 50cm Black
Its design combines tinned OFC copper conductors with a silver-plated OFC copper shielding and an ALU-PET foil, in order to limit electromagnetic interference while maintaining stable signal transmission. The flexible sheath with a 5mm outer diameter preserves the flexibility required for use with headphones or earphones.
Viablue EPC-4 T8 Stereo Small: Architecture
The cable conductors are made of tinned OFC copper strands. The shielding combines a silver-plated OFC copper spiral with an ALU-PET foil, with a capacitance reaching 90pF/m. The cable finish thus relies on a combination of silver-plated copper and tinned copper. The VIABLUE T8 Stereo Small connectors use a stereo Jack 3.5mm format and 24K gold plating. The whole is protected by a matte satin sheath, a flexible wrap and a VIABLUE Cobra protective sheath, while the cable has an outer diameter of 5mm, sheathing included.
Photo of the Viablue EPC-4 T8 jack 3.5mm connector
Diagram of the Viablue EPC-4 T8 Stereo Small cable
Aperçu du VIABLUE EPC-4 T8 Cable for Earphones Jack 3.5mm Stereo 50cm Black
1Flexible cable sheath
2Insulating foil
3Spiral shielding, silver-plated OFC copper strands
4Protective foil, silver ALU PET
5Inner conductor, tinned OFC copper strands
Technical specifications
Product typeJack 3.5mm cable
Connectors2x Jack 3.5mm
Length50cm
Shielding
Conductor materialsTinned OFC copper
Silver-plated OFC copper
Contact plating24K Gold
Cable diameter5mm with sheath
PackageSold individually
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorJack 3.5mm
Conductors material (Cable)Silver
VIABLUE EPC-4 T8 STEREO SMALL Stereo Male Jack 3.5mm Cable 50cm Black
The Viablue EPC-4 T8 Stereo Small is a stereo Jack 3.5mm to Jack 3.5mm cable. It uses tinned OFC copper conductors and features a capacitance of...
