Ideal for separate decoding of the amplification and in the connection of SACD stages.
Version 5.1 is normally used when decoding (channel separation) is performed by the receiver and not by the DVD player, as only a few High-end DVD players are able to perform such an operation.
The 75 Ohm TRANSIT cable can be used both in analog and digital mode. In 5.1 version it is usually connected to the Multi input input of the digital receiver.
SOMMERCABLE uses HICON HI-CM06 gold plated plugs, with Delrin insulation. The total diameter of the cable is Ø15mm.
| Length (m) | 1.5 |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | RCA |
| Conductors Plating (Cable) | None |
