VIABLUE NF-B RCA Subwoofer LFE RCA Interconnect Cable 1m
Reference : 1369
147,99 €tax incl.
123,33 € tax excl.
VIABLUE NF-B RCA Subwoofer Interconnect Cable 1m
The NF-B subwoofer RCA cables are NF cables specially designed for powerful and vigorous bass reproduction. The electrical capacitance between the inner conductor and the conductive screen has been increased by using an extra large diameter inner conductor. A thermoplastic material, low-density polyethylene (LDPE), is used as the insulator, which further increases the electrical capacity while maintaining the same dimensions. The capacity per meter of this type of cable can reach 128pF/m.
The NF-B RCA cables were developed especially for the connection of subwoofers. The transmission of signals focusing on the bass range is kept at a maximum so that the intensity is not lost over long distances. This allows the subwoofers to find the best possible location for the acoustic conditions of the room they occupy.
The NF-B subwoofer cable's extremely large inner conductor diameter provides significant power to your subwoofers. The triple shielding, consisting of a crisscrossed double spiral shield and a layer of semi-conductive low density polyethylene (LDPE), protects this massive inner conductor. NF-B RCA cables are assembled with gold-plated, Teflon-insulated XLS ViaBlue RCA plugs, which can be attached to the RCA terminals by rotating the socket. These plugs ensure extremely strong clamping and resistance-free contact. The integrated isolation transformer filter prevents internal interference between the conductor and the conductive shield of coaxial cables.
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
