VIABLUE NF-B T8 RCA to RCA Subwoofer Cable 1m Cobra
The Viablue NF-B T8 is an RCA to RCA interconnect cable designed to transmit analog signals intended for a subwoofer. It relies on an internal OFC copper conductor, combined with a capacitance of 125pF/m, in order to adapt transmission to low-frequency signals.
Reference : 22301
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 26-11-2026.
Viablue NF-B T8 RCA to RCA Subwoofer Cable OFC Copper Triple Shielding and Ferrite Filter 1m Cobra
Viablue NF-B T8: Thumbnail
Designed for connections between a subwoofer output and the input of a subwoofer, it combines a coaxial structure, triple shielding and a ferrite filter to limit electromagnetic interference. The gold-plated T8 RCA connectors ensure connection continuity, while the braided sheath protects the cable and facilitates its integration into the installation.
Viablue NF-B T8: Conductor architecture and electrical behavior
The solid internal conductor consists of fine strands of OFC copper and is surrounded by a dielectric insulating layer. The conductor and its insulation are then covered with a semi-conductive LDPE layer, followed by two counter-rotating spiral shields made of tinned copper and pure OFC copper. This arrangement forms a coaxial cable suited to the transmission of subwoofer signals.
This approach is extended by triple shielding combining the semi-conductive LDPE layer with the two copper shields, thereby limiting the signal’s exposure to electromagnetic interference. The ferrite filter reduces high-frequency electromagnetic interference present in electronic circuits, while the gold-plated T8 RCA connectors ensure stable contact pressure. The assembly is covered with a flexible braided sheath and has an external diameter of 9.5mm.
Viablue NF-B T8: Cable
Viablue NF-B T8 cable diagram
Viablue NF-B T8: Internal diagram
1Flexible cable sheath
2Insulating foil
3Clockwise spiral shield, strands made of tinned OFC copper
4Counter-clockwise spiral shield, strands made of pure OFC copper
5LDPE semi-conductive layer
6Dielectric / insulator
7Internal conductor, strands made of pure OFC copper
Product typeSubwoofer cable
Length1m
Connectors2x RCA
Cable conductor materialOFC copper
Shielding materialTinned copper and pure copper
Connector contact platingGold
Conductor capacitance125pF/m
Cross-section2.08mm² (AWG14)
ColorCobra
PackagingSold individually
Length (m)1.0
ShieldingYes
Section (mm²)2.00
ConnectorRCA
Conductors Plating (Cable)Copper
Conductors Plating (Cable)Tin
VIABLUE NF-B T8 RCA to RCA Subwoofer Cable OFC Copper Triple Shielding and Ferrite Filter 1m Cobra
The Viablue NF-B T8 is an RCA to RCA interconnect cable designed to transmit analog signals intended for a subwoofer. It relies on an internal OFC...
