By buying this product you get 30 loyalty points
VIABLUE NF-S1 Mono RCA Interconnect Cable 3m (Pair)
This Viablue NF-S1 Interconnect cable reproduces music with high fidelity at all frequencies. It transmits the sound linearly and without distortion. The 2 silver plated shields preserve the most subtle variations of the signal and especially the high frequencies.
Its construction is balanced, that is to say that it has 2 conductors instead of one in a coaxial cable. Each conductor has 19 tinned wires of 0.185mm diameter, i.e. an equivalent section of 0.5mm².
The quadruple shielding is composed of 2 ALU-PETP (Polyethylene terephthalate) films and 2 silver plated braids reversed to each other. This superposition of different shielding ensures a 100% coverage. The external diameter of the NF-S1 is 8mm.
Viablue cables are equipped with gold-plated and Teflon-insulated XLS connectors. The ferrites installed at each end cancel the interference that can occur on the cable jacket.
Capacity between 2 conductors: 50pF core/core
Capacitance between conductors and shield: 100pF core/screen
| Length (m) | 3.0 |
| Shielding | Yes |
| Section (mm²) | 0.50 |
| Connector | RCA |
| Conductors Plating (Cable) | None |
