SHANLING CD80II CD Player Black
Rediscover your CD collection with the Shanling CD80II, a compact CD player that combines the timeless charm of CDs with the modern versatility of Hi-Res Audio and wireless connectivity. More than just a CD player, it is the ideal digital heart for any Hi-Fi system, designed to blend discreetly into your space.
By buying this product you get 32 loyalty points
Reference : 21256
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 05-05-2026.
Shanling CD80II CD Player HD850 DAC CS43198 Headphone Amplifier SGM8262 Bluetooth 5.0 LDAC Black
Shanling CD80II
Shanling CD80II: Key features
Shanling CD80II: Modern design
The Shanling CD80II combines the design of the original CD80 with that of the latest CD-S100. The CD80II thus benefits from a modern yet understated appearance that can be integrated into any HiFi system. The device is encased in a sturdy aluminum chassis with a beautiful finish.
Shanling CD80II: A new screen, still compact in size
The CD80II features a 1.28-inch LCD screen and a brand new user interface, providing direct access to a wealth of information and functions. Measuring just 28 x 20 x 5cm, the CD80II is Shanling's most compact CD player model, ideal for desktop or rack mounting.
Shanling CD80II: Compact screen and format
Shanling CD80II: Reliable CD mechanism
The Shanling CD80II adopts the same 4th generation CD system as the high-end CD-S100 (25) model, combining an HD850 laser with a drawer-type mechanism for extremely accurate and convenient playback.
Shanling CD80II: Cirrus Logic CS43198 DAC
The CD80II features a Cirrus Logic CS43198 DAC chip offering both excellent measurements and beautiful sound reproduction that is both detailed and lively.
Shanling CD80II: DAC CS43198
Shanling CD80II: SGM8262 dual headphone amplifier
Compared to its predecessor, the CD80II focuses much more on headphone users and therefore incorporates a balanced headphone amplifier stage. Based on two SGM8262 chips, it is capable of delivering 2x215mW under 32Ω on its unbalanced 3.5mm jack output or 2x850mW under 32Ω on its balanced 4.4mm jack output, making it capable of driving both high-impedance headphones and more sensitive earphones.
Shanling CD80II: A complete range of connectors
The Shanling CD80II excels in its ability to handle all your music sources. In addition to CD playback, it is equipped with a USB port for connecting a USB stick or hard drive (up to 2TB) for playing high-resolution files. It effortlessly handles PCM up to 32-bit 384kHz and DSD256 (with support for DSD, DXD, FLAC, WAV, and other formats).
For wireless connectivity, the built-in Bluetooth 5.0 module allows you to easily stream music from a smartphone or tablet, supporting high-quality codecs such as LDAC, in addition to the traditional AAC and SBC.
In terms of outputs, it offers complete flexibility with analog RCA connections (2.6Vrms) and a digital coaxial output (S/PDIF) (up to 192kHz 24bit), for seamless integration into any HiFi system.
Shanling CD80II: Complete connectivity
Shanling CD80II: Controls & App
The front panel of the CD80II is equipped with several physical buttons for controlling playback and device settings. A remote control is also provided for remote control.
In addition, the free Eddict Player mobile app allows you to browse files stored on your connected USB devices.
Shanling CD80II: Remote control and control app
Shanling CD80II: Ingenic X1000E processor
The Shanling CD80II is equipped with a new Ingenic X1000E processor for smoother and more stable operation. The player starts up faster and responds more quickly.
Shanling CD80II : processor
Product typeCD player
InputsCD player
1x USB-A
Bluetooth 5.0
Outputs1x RCA
1x Coaxial
1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
1x Coaxial
ProcessorIngenic X1000E
DACCirrus Logic CS43198
Screen1.28" (240 x 240px) color screen
ControlsFront buttons
Remote control
Mobile app
Supported CD formatsCD / CD-RW / CD-R
USB Supported formatsDSD, DXD, APE, FLAC, ALAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, MP2, M4A, AC3, OPUS, TAK, CUE
Supported Bluetooth codecsLDAC, AAC, SBC
Output level (RCA)2.6Vrms
Frequency response20Hz-40kHz (-0.2dB)
THD+NRCA: 0.0004%
Headphone output: 0.0007%
Dynamic rangeRCA: 124dB
Jack 3.5mm headphone output: 125dB
Jack 4.4mm headphone output: 127dB
SNRRCA: 124dB
Jack 4.4mm headphone ouput: 127dB
Output impedanceRCA: 100Ω
Jack 3.5mm headphone output: 0.4Ω
Jack 4.4mm headphone output: 0.7Ω
Channel separationJack 3.5mm headphone output: 75dB @ 32Ω
Jack 4.4mm headphone output: 112dB @ 32Ω
Noise floorJack 3.5mm headphone output: 117dB (< 1.4µV)
Jack 4.4mm headphone output: 113dB (< 2.2µV)
Supported sampling ratesUSB: PCM up to 32bit 384kHz, DSD up to DSD256
Coaxial: PCM up to 24bit 192kHz
Supply voltage100-220V AC
Dimensions280 x 205 x 52mm
Housing materialAluminum
Weight2.6kg
Package1x Shanling CD80II
1x Power cable
1x Bluetooth antenna
1x Remote control
SHANLING CD80II CD Player HD850 DAC CS43198 Headphone Amplifier SGM8262 Bluetooth 5.0 LDAC Black
Rediscover your CD collection with the Shanling CD80II, a compact CD player that combines the timeless charm of CDs with the modern versatility of...
