SHANLING EC ZERO CD player
The Shanling EC Zero T CD player retains the design and features of its big brother, the EC Zero T, but with new components and a much more affordable price tag.
By buying this product you get 31 loyalty points
Reference : 21100
319,00 €tax incl.
265,83 € tax excl.
This product is temporarily unavailable.
Shanling EC Zero Battery Powered CD Player AK4493 SGM8262 Bluetooth 5.3
Photo du Shanling EC Zero
The Shanling EC Zero T CD player retains the design and features of its big brother, the EC Zero T, but with new components and a much more affordable price tag. Its circuitry has been simplified and the tubes have been removed to make way for SGM8262 amplifiers. On the digital-to-analog conversion side, an AK4493 DAC chip now processes the signal. However, the exceptionally stable servo architecture, a robust battery offering up to 10 hours of battery life, and extensive connectivity offering numerous possibilities for use have been retained. In terms of aesthetics, the retro-futuristic design featuring numerous physical buttons and a volume slider remains. The sturdy tempered glass and aluminum chassis has also been retained.
Les avantages du Shanling EC Zero
Shanling EC Zero overview
1Stop
2Play / Pause
3Function selector
4Previous track
5Next track
6Lock button
74.4mm jack output
83.5mm jack output
9SPDIF Coaxial/Optical Output
10Bluetooth antenna
11USB-C DAC input
12USB-C power port
13Power mode switch
Product typeCD player
ChipAK4493S
AmplificationSGM8262
Input1x USB-C DAC input
Outputs1x 3.5mm unbalanced headphone output
1x 4.4mm balanced headphone output
1x 3.5mm unbalanced line output
1x 4.4mm balanced line output
1x SPDIF coaxial/optical output
Bluetooth
Supported sample rate (USB DAC)PCM jusqu'à 32bit 768kHz
DSD jusqu'au DSD512
Bluetooth version5.3 bidirectional
Bluetooth transmission codecsSBC, aptX, aptX Adaptive
ScreenLCD 1.68"
CD ripper1x Speed, to FAT32, WAV format
3.5mm headphone jack output
Output powerLow gain: 52mW @ 32 ohms
High gain: 122mW @ 32 ohms / 213mW @ 32 ohms (with external power supply)
THD+N0.0004%
Dynamic range117dB
Channel separation79dB
SNR117dB
Noise111dB (Low gain)
Frequency response (DAC USB)20Hz-40kHz (-0.5dB)
Frequency response (Lecture CD)20Hz-40kHz (-0.5dB)
Output impedance0.6 ohm
4.4mm headphone jack output
Output powerLow gain: 221mW @ 32 ohms
High gain: 525mW @ 32 ohms / 836mW @ 32 ohms (with external power supply)
THD+N0.0004%
Dynamic range119dB
Channel separation103dB
SNR119dB
Noise107dB (Low gain)
Output impedance0.8 ohm
3.5mm jack output
Output power2.05Vrms
Frequency response20Hz-40Hz (-0.5dB)
THD+N0.0005%
SNR117dB
4.4mm jack output
Output power4.1Vrms
THD+N0.0005%
SNR119dB
Battery5500mAh
Battery lifeUp to 10h (analog/optical outputs)
Up to 18h (Bluetooth transmission)
Power supply5V 2A
Dimensions158 x 150 x 28mm
Weight575g
ColorGray
Package1x Shanling EC Zero T
1x USB-A to USB-C cable
SHANLING EC ZERO Battery Powered CD Player
The Shanling EC Zero T CD player retains the design and features of its big brother, the EC Zero T, but with new components and a much more...
