SHANLING CD-S100 V25 CD Player DAC Black
With the CD-S100v25, Shanling is offering an updated version of its successful CD player. This new version is based on the architecture of the brand's ET3 CD player, adding additional functions to classic CD playback, such as USB drive playback, Bluetooth connectivity and compatibility with DLNA and Airplay network protocols.
By buying this product you get 58 loyalty points
Reference : 20816
589,00 €tax incl.
490,83 € tax excl.
Shipping date: 16-12-2025.
Shanling CD-S100 v25 CD Player DAC USB BD34352 32bit 768kHz DSD512 Black
Shanling CD-S100 v25 : Front view
This updated version incorporates a DS11 laser sensor coupled to a BD34352 DAC chip, capable of processing a signal well in excess of the sampling rate of the CD format, allowing full use to be made of the USB input with compatibility up to PCM 32bit 768kHz and DSD512. This solid technological backbone is powered by a 43VA R30 transformer.
Its numerous digital and analogue outputs and connectivity make it a flexible device with a much wider range of uses than a simple CD player, which can be used as a DAC thanks to its USB input or as a steamer thanks to its network and Bluetooth connectivity.
Product typeCD Player
DAC
InputsCD
1x USB-B
1x USB-A
Bluetooth
WiFi
1x Balanced stereo XLR
1x Optical Toslink
1x Coaxial
Network protocolsDLNA
Airplay
DAC ChipROHM BD34352
AOPOPA1612
MUSES8920
Supported sampling ratesUSB-A: PCM up to 32bit 768kHz / DSD up to DSD512
USB-B: PCM up to 32bit 384kHz / DSD up to DSD256
Total harmonic distortion more noise(THD+N)Single-ended: 0.0007%
Balanced: 0.0005%
Signal-to-noise ratio (SNR)Single-ended: 118dB
Balanced: 120dB
Dynamic RangeSingle-ended: 118dB
Balanced: 120dB
Lineout output levelSingle-ended: 2.1Vrms/10kΩ
Balanced: 4.2Vrms/10kΩ
Channel separationSingle-ended: 117dB
Balanced: 119dB
Frequency Response20Hz - 20kHz (±0.2dB)
ProcessorIngenic X2000
Supported file formatsDSD, DXD APE, FLAC, WAV, AIFF/AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, OPUS, TAK, CUE
Bluetooth version5.0
Dimensions429 x 300 x 83.5mm
Weight6.1kg
Package1x Shanling CD-S100 v25
1x Remote control
1x Power cable
SHANLING CD-S100 V25 CD Player DAC USB BD34352 32bit 768kHz DSD512 Black
With the CD-S100v25, Shanling is offering an updated version of its successful CD player. This new version is based on the architecture of the...
