THINKYA R02 CD Player
The Thinkya R02 is a compact CD player with integrated amplification designed for autonomous and versatile use, combining optical playback and wireless transmission. It relies on an integrated architecture pairing dual 2 x 1.5W stereo speakers with bidirectional Bluetooth 5.0 connectivity, enabling both direct reproduction and signal transmission to external devices.
Reference : 22105
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 01-12-2026.
Thinkya R02 Battery-Powered CD Player Bluetooth 5.0
Thinkya R02 : Front view
The Thinkya R02 is a compact CD player with integrated amplification designed for autonomous and versatile use, combining optical playback and wireless transmission. It relies on an integrated architecture pairing dual 2x1.5W stereo speakers with bidirectional Bluetooth 5.0 connectivity, enabling both direct reproduction and signal transmission to external devices.
Intended for home or semi-portable use, it combines CD playback, extended USB compatibility and a built-in 2600mAh battery, allowing different audio sources to be centralised within a compact format. This approach is further reinforced by a wooden chassis that limits mechanical vibrations.
Thinkya R02: Bidirectional Bluetooth 5.0
The Thinkya R02 integrates bidirectional Bluetooth 5.0 connectivity, allowing it to receive an audio stream from a smartphone for use as a speaker, as well as transmit the signal to a wireless headphone or speaker, ensuring flexible adaptation to different use cases.
Thinkya R02 : Connectors view
Thinkya R02: USB Playback
Beyond CD playback, the R02 supports USB media up to 32GB, enabling playback of WAV, APE, FLAC, AAC, MP3 and WMA files to expand audio sources without prior conversion. This extended compatibility allows digital content to be centralised while maintaining consistent reproduction across a 20Hz to 20kHz range.
Thinkya R02: Built-in 2600mAh Battery
The player relies on a 2600mAh battery, enabling autonomous use without immediate dependence on an external power supply. This approach facilitates integration into mobile or semi-portable use.
Thinkya R02 : Drawing
Thinkya R02: Wooden Chassis
The wooden chassis provides a denser structure than conventional plastic constructions, limiting parasitic vibrations generated by the CD mechanism and speakers, resulting in more stable reproduction. This design is further complemented by careful integration of the acoustic elements, contributing to signal coherence within a compact 195 x 160 x 43mm format.
Thinkya R02: 2x1.5W Integrated Amplification
The R02 houses two 1.5W stereo speakers, enabling direct reproduction without external equipment. This configuration is complemented by passive bass reinforcement, supporting the lower end of the spectrum while preserving clarity in the vocal and treble registers, resulting in autonomous listening suited to home or secondary use.
Thinkya R02 : Speakers
Product typeCD player
Inputs1x 3.5mm jack
1x USB-A
CD
Bluetooth
Outputs1x Optical Toslink
1x 3.5mm headphone jack
Bluetooth
Bluetooth version5.0
Supported formatsCD-DA/MP3 (CD-R/RW)
Signal-to-noise ratio (SNR)≥80dB
Frequency response20Hz-20kHz
Output power2x1.5W
Battery2600mAh/3.7V
Supply voltage5V 3A
Weight626g
Dimensions195 x 160 x 43mm
ColorWood
Package1x Thinkya R02
1x Remote control
1x USB-A to USB-C cable
1x 3.5mm jack to 3.5mm jack cable
THINKYA R02 Battery-Powered CD Player Bluetooth 5.0
The Thinkya R02 is a compact CD player with integrated amplification designed for autonomous and versatile use, combining optical playback and...
