BURSON AUDIO SUPREME SOUND SS OPAMP V5 Dual Discrete OPA (Unit)
Reference : 11696
69,90 €tax incl.
58,25 € tax excl.
BURSON presents this time the 5th generation of operational amplifiers with discrete components of the famous Australian firm.
Inmore compact and more efficient, they are now less prone to voltage and current.
Un research and development project in direct contact with many sound professionals and renowned musicians.
These gifted circuits have managed to make their way into some professional production and recording studios.
Generally AOPs in the form of integrated circuits are made for industrial use.
When used in a Hi-Fi system performance is far from extraordinary.
Discrete AOPs use components sorted to tight tolerances and audiophile grade resistors.
Combined with a dedicated audio quality scheme, you get a soft, natural sound.
VWe therefore have every interest in replacing conventional PDOs with discrete component PDOs, except for congestion.
Thethe latest in the Burson PDOs is Gold Plated Pin, TKD 50ppm resistors and FET in and out transistors.
In addition, the welds of both PCBs have been reduced by laser cutting and an insulation film has been inserted so that they do not touch each other (double AOP version only).
Direct AOP stereo replacement for:
Dual Op-Amps:AD823, AD823AN, AD8066, AD8620, NJM4558, NJM4558, NJM4558D, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, AD712, AD827, C4570, JRC4580, JRC5532, JRC5532D, JRC5534, LF353, LM4562, LM833N, LME49860, MUSES8920, NE5532, NEC4520, , OPA2277A, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072.
<Features/ Strong>:
  • Resistors TKD 50ppm (Japan)
  • Transistors FET (input / output)
  • Min / Max Voltage: 3.5V to 15V
  • Removable DIP8 holder
  • Gold plated contacts
  • Hand-Paired Components
  • Dimensions: 29x12.4x14.5mm (excluding socket)
OPA TypeDual
