MUNDORF MCAP EVO Capacitor 650V 0.01µF
Reference : 9616
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 16-09-2026.
Condensateur Mundorf Mcap EVO
Mundorf Mcap EVO
Mundorf's Mcap EVO capacitors have gone through a high precision winding process before being hand-mounted in a shell layer specifically designed to reduce vibration and microphonics.
The particular shape of these capacitors as well as their robust construction allows for horizontal or vertical mounting without affecting performance or durability.
The inner coil has a narrow and tall profile. An unusual feature that results in a better ESR (equivalent resistance) and a reduced ESL (equivalent inductance). Indeed, a long and tight coil facilitates the signal path while increasing the number of windings traveled: redoubled efficiency and controlled size.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance0,010 µF
Voltage650V
Tolerance±5%
Diameter12mm
Lengthr12mm
Connect wire diameter0,6mm
Connect wire length (A)35mm
Connect wire length (B)35mm
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)5
Capacitor capacitance (µF)0.01
Rated voltage (V)650.0
Capacitor typeFilm capacitor
Capacitor formatAxial
