The Arylic H50 amplifier is a compact, versatile and high-performance FDA stereo amplifier. It achieves an output power of up to 2x50W into 4Ω, and features quality components such as a Bluetooth 5.2 QCC3040 receiver/transmitter chip and an ESS ES9023P DAC chip, enabling it to support sampling rates up to PCM 24bit 192khz. In addition to its Bluetooth 5.2 functionality, it is WiFi connected and compatible with a large number of streaming services. Arylic has even made its amplifier compatible with a control application, available on IOS and Android, called 4stream. Moreover, it features a wide range of connections, including the essentials, plus a subwoofer output, a phono input and an HDMI ARC input.
The main strength of Acrilyc's H50 is its wireless connectivity. In fact, it works with streaming protocols such as Airplay 2, Alexa, Spotify connect, Tidal connect, DLNA UPnP and Qplay. It is also compatible with a large number of online streaming services: Spotify, Tidal, Deezer or Qobuz, Amazon music, Napster and more. It features a WiFi antenna and an RJ45 ethernet port. The Ethernet port lets you connect without using the 4Stream control application, and play your music directly from your smartphone.
Thanks to a Qualcomm QCC3040 chip, the H50 is able to receive and transmit different Bluetooth codecs: SBC, ACC, aptX HD, aptx LL, AptX AD. Bluetooth functionality also enables you to pair 2 devices simultaneously, such as Bluetooth speakers or headphones, to share your music with friends and family.
A subwoofer output on RCA connector lets you transform your 2.0 system into a 2.1 system with an active subwoofer for a more immersive listening experience. Coupled with the HDMI ARC input port, the H50 can be transformed into a small home theater amplifier. In addition, it's CEC-compatible, so you can control your TV's power and volume with a single remote control.
The H50 can be operated with the 4Stream control app, available for free on Android and iOS. This allows you to remotely control your music playback, and also to set up a multiroom system, controllable independently or by zones. The control app also features a 10-band equalizer, so you can customize your listening experience to suit your preferences.
Arylic has also equipped its H50 amplifier with a phono input so you can enjoy your vinyl collection. This phono input is compatible with MC and MM cell turntables.
The H50 comes with a remote control that offers a wide range of functions. In addition to the traditional play/pause/previous/next and volume controls, you can select your source device and manage bass/treble EQ.
1 | Bluetooth antenna |
2 | DC power connector |
3 | Speaker terminals |
4 | Switch 4/8Ω load |
5 | Phono input (Stereo RCA and GND) |
6 | Stereo RCA input |
7 | Subwoofer RCA output |
8 | Optical Toslink input |
9 | HDMI ARC input |
10 | LAN RJ45 input |
11 | USB-A input (U- Disk) |
12 | USB-C input |
13 | Reset button |
14 | WiFi antenna |
Product type | Amplifier |
Amplifier type | FDA |
DAC chip | ESS ES9023 |
Bluetooth chip | QCC3040 |
Inputs | 1* USB-C (DAC USB 48kHz) 1* USB-A (U Disk) 1* LAN RJ45 1* HDMI ARC 1* Optical Toslink 1* RCA stereo line input (2 Vrms max.) 1* Phono input (MM/MC compatible) Bluetooth WiFi |
Outputs | 1* Speaker terminals 1* RCA subwoofer output (3Vrms/250Hz) Bluetooth (2 devices simultaneously) |
Output power | 2x50W @4Ω (@ 24V) 2x 30W @8Ω (@ 24V) 2x50W @ 8Ω load at 24V (Boost) |
Speakers impedance | 4-8Ω |
Frequency response | 20Hz - 20kHz |
THD+N | < 0.1% @ 1W 1kHz |
SNR | > 93 db @ max. power |
Transmission protocols | Airplay 2, Alexa, Spotify connect, Tidal connect, DLNA UPnP and Qplay |
Compatible streaming services | Spotify, Tidal, Deezer, Qobuz, Napster, Pandora, Amazon Music, Internet radio, iHeartRadio, vTuner, Sound machine, Radio paradise, Calm radio, QQ music, QQ FM |
WiFi | IEEE802, 11 b/g/n 2.4g/5g |
Ethernet | 100Mbps |
Multizone function | With 4Stream or Airplay 2 |
Screen | 2.23" OLED |
Power supply | 24V DC 16A |
Dimensions | 185*155*50mm |
Weight | 901g |
Package | 1* Arilyc H50 1* Bluetooth antenna 1* WiFi antenna 1* Remote control 1* AC adapter 24V 4.16A with DC power cable |
Input | Phono |
Input | HDMI ARC |
Input | USB |
Input | Optical |
Input | RJ45 |
Input | WiFi |
Input | RCA |
Input | Bluetooth |
Output | Subwoofer |
Output | Speaker terminal |
Output | Bluetooth |
DAC / ADC Chip | ES9023 |
Max sampling rate | 192kHz |
Color | Black |
Channel | 2 (Stereo) |
Channel | 2.1 |
Class | FDA |
Amplifier chip | N/A |
Power (W) | 50.0 |
Remote Control | Yes |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
