Max cable diameter (mm)
Section (mm²)
0 mm - 50 mm
Contacts Material (Connector)
Contacts Plating (Connector)
Marcus L.
Michael M.
Worth every penny!
mathieu l.
Crimp Sleeves
Discover our range of crimp connectors, in various diameters, to quickly and easily assemble your own HiFi audio cables.
