IAN CANADA RECEIVERPI PRO II Interface SPDIF I2S HDMI for Raspberry Pi
Ian Canada's ReceiverPi Pro II is designed for Raspberry Pi-based DDC or DAC projects, to retrieve a digital audio stream from multiple sources rather than from the Raspberry Pi itself. The ReceiverPi Pro II can select a digital signal from any of the following inputs: coaxial, Toslink optical, I2S via HDMI or Raspberry Pi GPIO.
Reference : 18283
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 06-05-2025.
Ian Canada ReceiverPi Pro II
Ian Canada ReceiverPi Pro II Récepteur SPDIF / I2S pour DDC ou DAC Raspberry Pi
The ReceiverPi Pro II features an additional control input that can be connected directly to a MonitorPi Pro (sold separately), which functions as an integrated control center. The ReceiverPi Pro II's PCB layout has also been optimized, so there's no problem when it's installed just below a FifoPiQ7 (sold separately). It can also work with a StationPi Pro (sold separately).
Key features:
  • 75Ω coaxial SPDIF input up to 192kHz, isolated.
  • Isolated Toslink optical input up to 192kHz.
  • I2S/DSD via HDMI input up to PCM 768kHz and DSD1024.
  • I2S/DoP via Raspberry Pi GPIO up to PCM 768kHz and DSD128.
  • Can be used without Raspberry Pi.
  • Can be easily configured as a FIFO SPDIF by integrating it with a FifoPi and a TransportPi (sold separately).
  • Can be easily configured as an HDMI interface with an HdmiPi or HdmiPi Pro (sold separately).
  • Works with StationPi Pro controller (sold separately).
  • Can be connected to MonitorPi Pro (sold separately) as a DDC control center.
  • Optimized for use with FifoPi Q7 (sold separately).
  • Ideal for multi-input DAC or DDC projects.
  • Generates standard 48kHz phantom signals when SPDIF is unlocked.
  • GPIO port reserved for possible Linux/Web-based software control.
  • Plug & Play.
Product typeSPDIF / I2S receiver
Inputs1* Optical Toslink
1* Coaxial
1* I2S/DSD via HDMI (pinout PS Audio)
1* GPIO
Outputs1* GPIO
1* MCLK sur connecteur U.FL coaxial
Dimensions65*56.5mm
Mounting holes spacing58*49mm
InputI2S
InputI2S via HDMI
OutputGPIO
DAC / ADC ChipNC
Max sampling rateDSD1024
Max sampling rate768kHz
Ian Canada's ReceiverPi Pro II is designed for Raspberry Pi-based DDC or DAC projects, to retrieve a digital audio stream from multiple...
