IAN CANADA TRANSPORTPI DIGI II Ultra Low Jitter Digital Audio Interface Module
With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next level. This module delivers a high-quality signal with very low jitter and noise thanks to Ian Canada's proprietary 3-stage 1-bit discrete reclocking technology for SPDIF signals, and 2-stage multi-bit technology for I2S signals.
Reference : 19555
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 01-12-2026.
Ian Canada TransportPi Digi II Ultra Low Jitter Digital Audio Interface Module
TransportPi Digi II : Front view
This TransportPi Digi also has two slots for XO clocks so you can achieve a higher level of sound quality. Its multitude of outputs (coaxial, optical, HDMI, GPIO) makes it a very complete and versatile module. This product, combined with a very good power supply like the UcPI or PurePi, makes it one of the best digital interfaces for Raspberry Pi on the market.
New feature in version II :
  • Supplied with high-quality FemtoMck 45.1584/49.1520 MHz clocks
  • Direct 3.3 V input optimised for high-quality, low-noise battery/ultracapacitor power supply
  • Mute function for I2S via HDMI
  • New S/PDIF digital transformer
  • Improved coaxial signal quality
Key features:
  • Four high-quality outputs: isolated coaxial (RCA) and reclocked optical S/PDIF outputs. I2S output via reclocked HDMI. Reclocked I2S output on GPIO.
  • 3-stage discrete 1-bit reclocking for SPDIF signals
  • 2-stage multi-bit discrete reclocking for I2S signals
  • Pre-installed 45.1584/49.1520 MHz local low noise clocks compatible with FiFoPi.  Replaceable XO clocks compatible with FifoPi.
  • High quality local MCLK output on U.FL coaxial connector
  • Can also operate as an I2S FIFO re-clocker
  • Clean low noise 3.3V power input: ideal for working directly with a LifePO4 battery. The built-in LDO can also be bypassed.
  • Can share power with the Raspberry Pi
  • Works with SinePi to take high quality external sine clocks
  • Supports PCM signals up to 192kHz
  • Four-layer PCB design with two inner PCB layers as dedicated shielding plates to further reduce noise
  • Enhanced power supply filter network with over 130 ultra-low ESR decoupling capacitors
  • Uses the standard WM8805 Linux driver
  • Bit-perfect and lossless
  • Easy-to-use, plug-and-play
TransportPi Digi II : Dimensions
The Ian Canada TransportPi Digi II module is sold separately. The Raspberry Pi is sold separately.
Type of productDigital interface
Input1x GPIO
Outputs1x GPIO
1x I2S LVDS (HDMI)
1x Optical Toslink
1x Coaxial
DSD supportHDMI output: Native DSD and DoP
S/PDIF outputs : DoP
Dimensions75 x 56.5mm
Holes spacing58 x 49mm
Package1x Ian Canada TransportPi Digi II
4x Spacers and screws
4 reviews
Super Saund.
This review has been posted for IAN CANADA TRANSPORTPI DIGI II Ultra Low Jitter Digital Audio Interface Module
Josef
This sound card from IAN CANADA is absolutely amazing, (reference) the presentation and detail a great sound improvement. Like all products from IAN Canada, who is serious about music through Raspberry.
Very good for streaming with RPI
Compared to Ifi Zen Stream on coaxial output is more focused and the vocals timbre is more realistic. Amazing sound, relaxed, natural with a lot of detail. Highly Recomended!
grande évolution
Par rapport a la version précédente, il y a une nette évolution dans la qualité du son. De plus en mode coax les parasites emi ont disparu.
With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next...
