AUDIOPHONICS I-Sabre DAC ES9028Q2M Raspberry Pi 3, 2, A+, B+ / SPDIF & I2S
The DAB I-SABRE Es9028Q2M meets all the expectations of fans of its audio DIY for Raspberry Pi 3. Due to its advanced features it corresponds to a large number of use with a high sound quality 32bit 384Khz.
Strong points :
  • I2S and SPDIF inputs
  • Autonomous hardware management with digital encoder (option)
  • Visualization of the volume and the entries by OLED screen (option)
Reference : 12105
129,00 €tax incl.
107,50 € tax excl.
Our Audiophonics DAC ES9028Q2M has been updated to version ES9038Q2M.
Find this version ES9038Q2M on this page.
Audiophonics ES9028Q2M
DAC 32bit 768kHz / I2S & SPDIF
Audiophonics offers many improvements to its ES9028Q2M IAC Sabre DAC, especially in terms of functionality, while still offering exceptional sound performance.
Audio quality always bluffing
Like its predecessors, the ES9028Q2M delivers truly exceptional sound performance with selected components to ensure the most accurate and clean sound reproduction. Thus, it supports sampling rates up to 32bit 768kHz. Based on proven technologies, the 32bit Hyperstream offers a wider range of dynamics while drastically reducing the jitter that could lead to distortion.
An autonomous system
Like its predecessors, the ES9028Q2M fits perfectly with Raspberry Pi to offer a complete, flexible and powerful DAC. This converter innovates by offering a real hardware control, allowing it to operate in full autonomy, via its input I2S. In addition, installing drivers is no longer required for pto allow the operation of the DAC. These come only in addition to bring you a software management of your device.
An improved user experience
The 9028Q2M, in order to facilitate its use and ensure a high stability is loaded, via its microprocessor, to automatically detect the sampling rate of the source to adapt automatically. Thus, there is no problem decoding the signal and no artefact will appear listening.
Advanced analog output
Including two AOP NJM 2114 powered by 12V on the map corresponding to ESS technical drawings, the latest AOP NJM 2114 buffer finalizes the analog output stage, to ensure optimal playback.
PDO NNJM 2114
A complete solution
This converter also represents a truly complete solution, allowing you to add a high quality OLED screen for the display of sources, volume and bit rate, as well as a physical volume controller to be able to adjust.the volume simply, without having to go through a software or an application.
Audiophonics I-Saber ES9028Q2M
Warning: This product contains only the Audiophonics I-Sabre ES9028Q2M DAC. The RaspBerry Pi, OLED screen, rotary encoder, and Kali are sold separately.
An efficient feed stage
Powered by a Micro USB 5V input, the DAC has a particularly well-designed power stage that both ensures a stable signal while reducing residual noise. For this, the PCB incorporates a Mornsun DC / DC converter providing voltage isolation of 3000VDC followed by two regulators and two 16V capacitors for stability.
In addition, as for its predecessor the Raspberry Pi can be powered directly via the GPIO port, thus avoiding multiple connections. You are also free to use a quality linear power supply to further improve the accuracy of decoding.
DietPi compatible
Our I-SABRE ES9028Q2M DAC is 100% compatible with the Open Source DietPi solution.
This solution allows to install a dedicated driver to directly control the DAC, and thusrofiter of ESS hardware volume control.
This can attenuate the output signal without losses, and thus use the DAC as a true preamplifier
The Dietpi solution is recommended to use Logitech Media server and / or ROON. But also allows to install other applications. Computer skills (SSH connection) are nevertheless necessary to correctly program this solution.
Click on the following logo to discover their site and their solutions to download.
DietPi
dietpi mixer
DietPi Mixer
Compatible Volumio
The ES9028Q2M is also compatible with the Volumio solution. Thus, it offers a web control interface that is both efficient and intuitive. What to enjoy fully and simply your music in high resolution.
Volumio
The DAC-ISABRE is 32bit 384KHZ compatible with the MoOde AUDIO distribution
To reach the 32 / 384Khz under MoOde Audio use the Advanced RT kernel:
Moode configuration
Video test by
The Hans Beekhuyzen Channel
Connectors
inputs1x GPIO (for Rasberry Pi)
1x I2S
1x SPDIF
Exits1x RCA Stereo
Sampling rateUp to 32 bit 768kHz (384k for RPI)
DSD 128 DOP auto switch
Dynamic range129dB
THD + N-120dB
Dimensions57 x 90mm
Weight40g
FoodMicro USB-B 5V (not included)
Attention, to connect a Raspberry Pi on the GPIO port, an additional connector is necessary.
raphe_standard "> ES9028Q2M
InputI2S
Channel2 (Stereo)
8 reviews
C'est le top !
DAC ISabre ES9028Q2M, avec le reclocker Kali et l'alim linéaire régulée, cable Mogami 3104 en bi-cablage sur des Tannoy D700. C'est le top.
Je n'aurais jamais cru que mes CD étaient aussi bons.
This review has been posted for AUDIOPHONICS I-Sabre DAC ES9028Q2M Raspberry Pi 3, 2, A+, B+ / SPDIF & I2S
Parfaite
très belle carte, manque tout simplement d'une notice (même) en anglais, le son est magique
Le meilleur hat dac
Oui, en combination avec le Kali il s'agit du dac avec le son le meilleur. Merci Audiophonics!
parfait !
voilà un achat que je ne regrette pas ! il se monte facilement sur un PI3, couplé à l'écran oled et un bouton rotatif, c'est une source parfaite . Il fonctionne aussi très bien en solo , il faudra juste souder une barrette de 5 broches (dommage que cela ne soit pas d'origine). reconnu sous volumio via un plugin et picoreplayer en natif.
AUDIOPHONICS DAC I-Sabre ES9028Q2M
Très bon DAC bas prix pour Raspberry Pi (à ma connaissance le meilleur). Je l'utilise avec un reclocker KALI + VOLUMIO. Le volume (HARDWARE) du DAC peut être piloté par VOLUMIO via un plugin mis à jour régulièrement en fonction des mise à jour du noyau Linux. il est compatible PCM 384Khz et DSD64 voir plus je crois (vive le monde de la haute définition). Le son est claire, limpide. J'ai un petit bémol sur la lecture des DSD64 (activer le DoP et ne pas laisser Direct sur VOLUMIO si non conversion en PCM), sur certains titre le son est atténué automatiquement, j'imagine que c'est un réglage de VOLUMIO.
Ça ne vos pas un DAC à 500€, 1000€... Le son a moins de relief, moins centré. Vous me direz ce n'est pas du tout le même prix! Et c'est vrais. Cela reste un très bon DAC pour jouer des fichiers Hautes définitions.
The DAB I-SABRE Es9028Q2M meets all the expectations of fans of its audio DIY for Raspberry Pi 3. Due to its advanced features it corresponds to a...
