HIFIBERRY DAC2 PRO DAC Board for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC2 Pro XLR is a high resolution digital to analog and analog to digital converter, dedicated to be used in combination with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B+, Zero). It is a sound card for Raspberry Pi optimized to enjoy high quality audio playback at a low price.
Reference : 15643
79,00 €tax incl.
65,83 € tax excl.
HiFiBerry DAC2 Pro XLR Module DAC XLR pour Raspberry Pi Burr Brown 24bit 192kHz
It is based on a Burr Brown conversion chip supporting sampling rates up to 24bit 192kHz PCM. It also embeds a low jitter clock circuit. The input is on a 40 pins GPIO header and the output on balanced stereo XLR. There is also a PCB connector to connect a DSP module to the DAC2 Pro XLR.
1GPIO input
2DSP extension (DSP board not included)
3Balanced XLR output
Product typeDAC Board
InputGPIO 40 pins
Output1x Balanced stereo XLR
CompatibilityRaspberry Pi A+, B+, 2B, 3B, 3B+, 4B+, Zero
Max output voltage4.2Vrms
SNR112dB
THD+N-93dB
Frequency response10Hz - 70kHz
Supported sampling ratesPCM up to 24bit 192kHz
Dimensions5.5 x 6.5 x 2.5cm
Weight30g
Consumption< 0.3W
InputGPIO
DAC / ADC ChipBurr Brown
Max sampling rate192kHz
The HiFiBerry DAC2 Pro XLR is a high resolution digital to analog and analog to digital converter, dedicated to be used in combination with a...
