AUDIOPHONICS DAC Sabre ES9018K2M I2S / SPDIF to RCA 32bit 384kHz DSD256
This cost-effective DAC module features a neat design and is ideal for compact DIY audio designs. It is based on an ESS ES9018K2M digital-to-analog conversion chip.
4.0 / 5
Reference : 15975
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 23-06-2026.
Audiophonics DAC Sabre ES9018K2M
Audiophonics DAC Sabre ES9018K2M I2S vers RCA 24bit 192kHz
This cost-effective DAC module features a neat design and is ideal for compact DIY audio designs. It is based on an ESS ES9018K2M digital-to-analog conversion chip. It also features a JRC4580D PDO in the output stage, a high-precision TXC clock, a filtered power supply stage and low-tolerance resistors to ensure accurate and detailed playback. The input is done in I2S on XH 2.54mm 6 poles connector or in SPDIF on solder pads, and the output in standard stereo RCA. The input is selectable via a simple jumper (J3) located under the board (Open = I2S / Closed = SPDIF).
I2S Wiring diagram
Schéma câble I2S Raspberry Pi
Product typeDAC module
Input1x I2S (XH 2.54mm 6 pins)
1x SPDIF on solder pads
Output1x Stereo RCA
DAC ChipESS ES9018K2M
DSD up to DSD256
Dynamic range127dB
THD+N-120dB
Niveau de sortie2Vrms
Impédance de sortie150 Ohm
Supply voltage5VDC 0.5A
Dimensions53 x 57mm x 15mm
CableXH 6 PIN to bare wire cable supplied
InputI2S
DAC / ADC ChipES9018K2M
Max sampling rate384kHz
Max sampling rateDSD256
4 reviews
Très correct pour ce prix
Comme il n'est pas programmé, il applique les valeurs par défaut.
Donc l' I2S c'est 32 bits obligatoirement.
Il monte jusqu'à 192kHz. Au delà il faudrait avoir une alimentation DVDD externe d'après la spec. Pas certain que ce soit le cas.
A noter: il sature à 0dBFS. Il vaut mieux éviter de dépasser -6dBFS.
This review has been posted for AUDIOPHONICS DAC Sabre ES9018K2M I2S / SPDIF to RCA 32bit 384kHz DSD256
Prometteur
J'en suis aux essais. Je le connecte à un FPGA qui génère DATA (2*32 bits) LRCK BCK (192k*64) MCLK (192k*128). Pas encore réussi à le faire fonctionner avec une FS de 384k. Il faut peut être que j'augmente la MCLK.
Une seule alimentation. Câble fourni. Distorsion au dessus de -6dBFS.
Works, but has a design flaw that can be overcome
The description says that the DAC can be used for I2S or S/PDIF signals and that switching can be done with jumper J3. Since I wanted to connect both types of input, I connected J3 with a toggle switch on the front of my Amp. S/PDIF signal from my CD drive and I2S from a Raspberry Pi and a HifiBerry Digi-Pro hat. Roon installed on the RPI. CD playing, with J3 closed worked well. As soon as an I2S signal is also send to the DAC, it switches to I2S, regardless of the position of J3. Also after switching off the I2S signal, it remains locked on I2S. Service desk of Audiophonics waved me away, saying basically that this is the way this DAC works. To me this is a design flaw that needed a resolution, which I have found. When switching to S/PDIF (closing J3), the I2S / BCK connection between the RPi/HifiBerry to the DAC needs to be interrupted. I use a dual toggle switch to do that, works well now. So first 5 stars with just CD, then to 1 star for not working as expected and finally to 3 because of the design flaw. For the money though a good sounding DAC with the option to upgrade the OPA to a better one. Greetings.
Avis DAC ES9018K2M
Je souhaitais faire évoluer le déjà bon DAC Sabre ES923, avec une version simplifiée du I-Sabre ES9038Q2M, ce DAC Sabre ES9018 répond à mon attente.
Mise en oeuvre avec un Raspberry pi et Moode audio version 7.61, la première impression subjective et qu'il est sensiblement plus détaillé, les plans plus précis, les basses plus profondes et plus fermes, avec une bonne dynamique.
Bonne carte DAC.
Penser à retirer le jumper J3 pour accéder à l'I2S.
This cost-effective DAC module features a neat design and is ideal for compact DIY audio designs. It is based on an ESS ES9018K2M digital-to-analog...
