DAC Board CS4398 CS8416 24bit 192kHz
This DAC module will allow you to enjoy a digital to analog conversion at a low price and ideal for integration in a DIY project. Its conversion stage is based on a CS4398 DAC chip, supporting PCM audio streams up to 24bit 192kHz. SPDIF reception is provided by a CS8416 chip. The module also integrates a NE5532P AOP on its output stage, mounted on DIP8 and therefore easily interchangeable.
Reference : 16528
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 16-09-2025.
DAC Board
Module DAC CS4398 CS8416 24bit 192kHz
For the connectic, we find in input Toslink optical and coaxial. For the outputs, the module provides stereo RCA and a second analog output on XH2.54mm 3 pins connector.
Product typeDAC Board
DAC ChipCS4398
SPDIF ReceiverCS8416
Inputs1x Optical Toslink
1x Coaxial
Outputs1x Stereo RCA
1x XH2.54mm 3 pins
Supported sampling ratesPCM up to 24bit 192kHz
SNR> 120dB
Dynamic range> 120dB
THD+N-107dB
Supply voltageDouble 12VAC
Dimensions82 x 50 x 22mm
Weight40g
OutputXH 2.54mm
DAC / ADC ChipCS4398
Max sampling rate192kHz
This DAC module will allow you to enjoy a digital to analog conversion at a low price and ideal for integration in a DIY project. Its conversion...
