Surprisingly good sounding dac. And cheap ! With Ian Canada fifopi ,hdmi receiver works smoothly...but clocks must be 22 and 24 MHz ...according to pcm1794 datasheet
2x PCM1794A I2S 24bit 192kHz
This simple but beautifully designed balanced DAC module is based on the integration of a pair of PCM1794A digital to analog conversion chips, each dedicated to a channel. These allow it to support sampling rates up to PCM 24bit 192kHz, while delivering a balanced, round and musical sound. This parallel integration also ensures an improvement of the dynamic range and the signal/noise ratio, these reaching 132dB. This conversion section is followed by a beautiful output stage, including four AOP 5532DD and six AOP 5534D.
As for the connections, the module offers an I2S input on solder pads as well as a balanced XLR output and a single-ended RCA output. Another output can be added thanks to the soldering pads present between the connectors already in place.
| Specifications | |
| Product type | DAC board |
| DAC Chip | 2x PCM1794A |
| Input | 1x I2S on solder pads |
| Outputs | 1x Balanced XLR 1x Single-ended RCA 1x Analog output on solder pad |
| OPA | 4x 5532DD 6x 5534DD |
| Supported sampling rates | PCM up to 24bit 192kHz |
| General | |
| Supply voltage | Digital stage: 5VDC Analog stage: ±12VDC |
| Dimensions | 128 x 100mm |
| Mounting holes spacing | 120 x 88mm |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Waldemar C.
M A.
