AUNE FLAMINGO BT Tube OP+BUF DAC Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
The Aune Flamingo is a tube DAC with a built-in headphone amplifier. The device is actually a hybrid structure, allowing you to use the tube circuit to enjoy a warm and round sound, or to select the operational amplifier section for a precise and clear reproduction. The Flamingo is a high-performance device that will also allow you to enjoy your high-resolution files, up to PCM 32bit 768kHz and DSD512.
By buying this product you get 26 loyalty points
Reference : 16869
269,00 €tax incl.
224,17 € tax excl.
Aune Flamingo BT
Aune Flamingo BT DAC à Tube OP+BUF Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
Bluetooth 5.0
In addition to its USB-B and coaxial inputs, the Aune Flamingo integrates a Bluetooth 5.0 receiver, allowing you to stream your music simply and remotely, from a smartphone or a tablet for example. The chip used supports the high-definition transmission codecs aptX HD and LDAC, for a sound reproduction of high quality even in wireless.
7 Digital filters
With its seven selectable digital filters, the Flamingo offers you the possibility to adapt its sound reproduction to your taste and your audio system. The following filters are available :
  • Apodizing Fast
  • Fast Linear
  • Slow Linear
  • Fast Minimum
  • Slow Minimum
  • Corrected Minimum
  • Brick Wall
A generous headphone amplifier
The OP+BUF section combined with the Flamingo's high current power supply gives it a great power reserve for its headphone amplifier circuit. It will thus be able to accompany most of the headphones on the market without difficulty.
A neat power supply
Special attention has been paid to the power supply of this Flamingo. This one allows to provide to all the audio circuits a clean and stable electrical signal, in an independent way.
High quality components
The manufacturing of the Flamingo shows the will of the brand to provide a high quality equipment. Aune has thus selected high-end components with high performances to equip its DAC.
Product typeDAC
InputsBluetooth 5.0
1x USB-B
1x Coaxial
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
Supported sampling ratesUSB : PCM up to 32bit 768kHz, native DSD up to DSD512
Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DoP128
Line output level @ 0dBOPA : 2Vrms Max
Tube : 1.9Vrms Max @ 0dBFS
Line output frequency responseOPA : 20Hz-20kHz ±0.02dB
Tube : 20Hz-20kHz ±0.6dB
Line output THD+N@ 1kHzOPA : 0.0003% @ 0dBFS
Tube : 0.02% @ -17dBFS
Line output noise floorOPA : 4µV
Tube : 20µV @ AES17 (20kHz)
Headphone output power45mW @ 300Ω, 0.05%
Headphone output THD+N @ 1kHzOPA : 0.0005%
Tube : 0.035%
Supply voltage12VDC
Housing materialAluminum
Dimensions135 x 101.1 x 27.1mm
Package1x Aune Flamingo BT
1x Remote control
1x Male USB-A to male USB-B cable
1x Male USB-B to female USB-C adapter
1x Male Jack 6.35mm to female Jack 3.5mm adapter
1x Power supply 12V
OutputJack 6.35mm
DAC / ADC ChipNC
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
The Aune Flamingo is a tube DAC with a built-in headphone amplifier. The device is actually a hybrid structure, allowing you to use the tube...
