By buying this product you get 54 loyalty points
Balanced Headphone Amplifier DAC AK4497 XMOS 32bit 768kHz DSD512 Silver
With this second version of the S6 series, Aune offers us a DAC and headphone amplifier combo based on the excellent AK4497 conversion chip from AKM. The device has a relevant and qualitative connectivity for an irreproachable integration in your audio system.
A 32bit DAC allows access to very high resolution files. The USB input supports PCM up to 32bit 768kHz and native DSD up to DSD512. The Coaxial input and the AES input support PCM up to 24bit 384kHz and DSD up to DoP128. Finally, the Optical input can read files up to PCM 24bit 192kHz and DSD DoP64.
Each channel constituting the stereophony benefits from its own preamplification circuit. This ensures excellent signal stability on the balanced and unbalanced outputs, with a well-defined sound stage. The unit was measured at -132dB crosstalk with a harmonic distortion rate (THD @ 1kHz) of 0.0005%, a dynamic range of 119dB and a signal-to-noise ratio (SNR) of 118dB.
The S6 Pro combines one of the most powerful DAC models with an amplifier circuit built around a proven preamplifier/headphone channel. The headphone amplification stage leads to an unbalanced 6.35mm jack output on the front panel as well as a balanced XLR 4-pin output.
The balanced XLR output delivers up to 405mW of power at 300Ω, while the unbalanced 6.35mm jack output is capable of outputting 120mW at equivalent load. A large power reserve that allows you to power demanding headphones.
With an impressive array of connectivity options, the S6 Pro is equipped with an AES/EBU digital input, a Coaxial port and an Optical input. The USB-B port will connect the S6 Pro to a computer or even an OTG compatible smartphone/tablet to enjoy the rest of the system in the blink of an eye without sacrificing audio quality.
On the output side, the S6 Pro offers the option between unbalanced stereo RCA and balanced stereo XLR for its line outputs. On the headphone output side, the unit offers an asymmetrical 6.35mm jack and a balanced 4-pin XLR.
Product type | Headphone amplifier DAC |
DAC Chip | AKM AK4497 |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial 1x AES |
Outputs | 1x Single-ended line output stereo RCA 1x Balanced line output stereo XLR 1x Single-ended headphone output Jack 6.35mm 1x Balanced headphone output XLR 4 pins |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Coaxial : PCM up to 24bit 384kHz, DSD up to DoP128 Optical : PCM up to 24bit 192kHz, DSD DoP64 AES : PCM up to 24bit 384kHz, DSD up to DoP128 |
Frequency response [Line output] | 20Hz-20kHz ±0.2dB |
Dynamic range [Line output] | 119dB |
SNR [Line output] | 118dB |
THD+N [Line output] | 0.0005% @ 1kHz |
Crosstalk [Line output] | -132dB |
Output level [Line output] | RCA : 2Vrms XLR : 4Vrms |
Power | Balanced XLR : 405mW @ 300Ω Single-ended Jack 6.35mm : 120mW @ 300Ω |
Housing material | Aluminium |
Color | Silver |
Package | 1x Aune S6 Pro 1x Power cable 1x USB cable 1x USB flash drive (with driver) 1x Male Jack 6.35mm to female Jack 3.5mm adapter |
Input | SPDIF |
Input | AES/EBU |
Input | Optical |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
Color | Silver |
Remote Control | No |
