By buying this product you get 31 loyalty points
Headphone Amplifier Balanced 32bit 768kHz DSD512
The Aune X1s GT is an elegant and powerful desktop DAC and amplifier, belonging to the 8th generation X1. Its optimized and neat architecture allows it to support high resolution files, up to PCM 32bit 768kHz and DSD512 via the USB input or 24bit 192kHz and DSD128 from the Coaxial and Optical inputs.
Versatile, it has a complete connectic with USB-B, Optical Toslink and Coaxial inputs, as well as a BNC input to associate an external 10MHz clock to the X1s GT. On the output side, we can count on stereo RCA line and pre-out, as well as two headphone outputs in single-ended Jack 6.35mm and balanced Jack 4.4mm format.
The amplifier stage of the Aune X1s GT uses four discrete amplifiers with no less than 96 bipolar transistors in total.
The Aune X1s GT also offers features such as clock synchronization and PLL technology as well as seven filters to tailor the unit's output to your listening style.
Product type | DAC Headphone amplifier |
USB chip | XMOS |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial 1x BNC for 10MHz clock |
Outputs | 1x Line stereo RCA 1x Pre-out stereo RCA 1x Single-ended Jack 6.35mm headphone output 1x Balanced Jack 4.4mm headphone output |
Supported sampling rates | USB : PCM up to 32bit 768kHz DSD up to DSD512 Coaxial / Optical : PCM up to 24bit 192kHz, DSD up to DSD128 |
Power supply supplied | Meanwell 9V 2.55A (5.5 / 2.1mm Jack) |
Input | SPDIF |
Input | BNC |
Input | USB |
Input | Optical |
Output | Jack 4.4mm |
Output | Jack 6.35mm |
Output | RCA |
DAC / ADC Chip | Burr Brown |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | N/A |
