The DAC DOGE 7 has many advantages, coupling a 32BIT ES9018 DAC 32BIT with an analog stereo output with 6 tubes of type 12AX7 X4 and 12AT7 X2. It thus includes the best of both worlds, analysis, high definition and analog heat.
GOOD POINTS:
By buying this product you get 184 loyalty points
ES9018VALVE DAC DSD256 XMOS XLR OUTPUT
The DOGE 7 features a Es9018 S DAC recognized for its exceptional capacity in terms of details, musical follow-up on 16bit files as well as High Definition. Resulting from a long 2.5 years of research, Doge offers an original DAC with an atypical stereo analog output in the small world of 32bit DACs. In addition, this DAC has one of the most powerful headphone outputs even for high impedance models of 600 Ohm.
The Doge 7 has 6 original Shuguang 12AX7 and 12AT7 tubes on its analog output. Thus it is a truly symmetrical scheme and high level RCA. We therefore take advantage of the unboundness and timbre of the tubes with the analysis capability of a 32-bit 384Khz DAC of the latest generation. The DOGE 7 uses the best components on the market with Clarity Cap MKP, Wima capacitors.
The DOGE 7 has all the digital inputs and outputs necessary for its proper operation. Featuring 110 Ohm digital input and XLR or RCA outputs with variable volume, the DOGE 7 can quietly attack a power amp or active speakers such as a studio monitor.
Description | |
DAC TYPE | ESS SABRE ES9018S |
Supported sampling frequency | jusqu'à 384kHz/32bit |
USB DSD support | DSD64 DSD128 DSD256 |
PCM support | To 32bit 384khz on USB, 24bit 192khz on coaxial, optical and AES EBU |
Preamplifier function | Digital variable level preamplifier 32/64bit ESS SABRE Hyperstream |
Headphone input | On jack 6.35mm dicret components stage |
Remote function | Fonction : play, pause next, back, volume, input selection |
Box Structure | black Aluminum |
Line out Specification | |
harmonic distortion level | <0.04% |
Noise dynamic ratio | >103dB |
Frequency response | 20Hz ~ 20kHz |
Level output | 2.6V on 600 Ohm RCA ( 4.5V XLR ) |
Specifications digital input and analogic output | |
USB | 32bit 384KHZ |
1 and 2 coxial input SPDIF | 24bit 192Khz impedance 75 ohm |
Optical Toslink 1 and 2 | 24 bit 192Khz |
AES EBU SPDIF | 24bit 192khz impedance 110 ohm |
RCA Output | two output stereo 2.6v impedance 600 ohm |
Sorties XLR symétrique | One Stereo output 4.5V |
Digital input sensibility | coaxial SPDIF 200mV |
Various | |
Dimensions | 440mm, 145mm, 110mm |
Weight | 16kg |
Voltage | 240V |
Input | Jack 3.5mm |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9018 |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Color | Black |
