DOGE 7 DAC ES9018S / XLR / RCA DSD / DXD XMOS TUBES 32bit 384kHz DSD256 XMOS
The DAC DOGE 7 has many advantages, coupling a 32BIT ES9018 DAC 32BIT with an analog stereo output with 6 tubes of type 12AX7 X4 and 12AT7 X2. It thus includes the best of both worlds, analysis, high definition and analog heat.
GOOD POINTS:
  • DAC ES9018S
  • 32bit 384kHz / DSD256
  • XMOS USB support
  •  6 tubes valves Real XLR balanced and RCA outputs
  • Digital Preamplifier with good headphone amplifier
By buying this product you get 184 loyalty points
Reference : 12413
1 849,00 €tax incl.
1 540,83 € tax excl.
DOGE 7
ES9018VALVE DAC DSD256 XMOS XLR OUTPUT
The DOGE 7 features a Es9018 S DAC recognized for its exceptional capacity in terms of details, musical follow-up on 16bit files as well as High Definition. Resulting from a long 2.5 years of research, Doge offers an original DAC with an atypical stereo analog output in the small world of 32bit DACs. In addition, this DAC has one of the most powerful headphone outputs even for high impedance models of 600 Ohm.
XLR, RCA Six Valve Output
The Doge 7 has 6 original Shuguang 12AX7 and 12AT7 tubes on its analog output. Thus it is a truly symmetrical scheme and high level RCA. We therefore take advantage of the unboundness and timbre of the tubes with the analysis capability of a 32-bit 384Khz DAC of the latest generation. The DOGE 7 uses the best components on the market with Clarity Cap MKP, Wima capacitors.
variable volume, AES / EBU 110 Ohm input
The DOGE 7 has all the digital inputs and outputs necessary for its proper operation. Featuring 110 Ohm digital input and XLR or RCA outputs with variable volume, the DOGE 7 can quietly attack a power amp or active speakers such as a studio monitor.
Technicals Caractheristics
Description
DAC TYPEESS SABRE ES9018S
Supported sampling frequencyjusqu'à 384kHz/32bit
USB DSD supportDSD64
DSD128
DSD256
PCM supportTo 32bit 384khz on USB, 24bit 192khz on coaxial, optical and AES EBU
Preamplifier functionDigital variable level preamplifier 32/64bit ESS SABRE Hyperstream
Headphone inputOn jack 6.35mm dicret components stage
Remote functionFonction : play, pause next, back, volume, input selection
Box Structureblack Aluminum
Line out Specification
harmonic distortion level<0.04%
Noise dynamic ratio>103dB
Frequency response20Hz ~ 20kHz
Level output2.6V on 600 Ohm RCA ( 4.5V XLR )
Specifications digital input  and analogic output
USB32bit 384KHZ
 1 and 2 coxial input SPDIF24bit 192Khz impedance 75 ohm
Optical Toslink 1 and 224 bit 192Khz
AES EBU SPDIF 24bit 192khz impedance 110 ohm
RCA Outputtwo output stereo 2.6v impedance 600 ohm
Sorties XLR symétriqueOne Stereo output 4.5V
Digital input sensibilitycoaxial SPDIF 200mV
Various
Dimensions440mm, 145mm, 110mm
Weight16kg
Voltage240V
InputJack 3.5mm
OutputJack 3.5mm
DAC / ADC ChipES9018
Max sampling rate384kHz
Max sampling rateDSD256
The DAC DOGE 7 has many advantages, coupling a 32BIT ES9018 DAC 32BIT with an analog stereo output with 6 tubes of type 12AX7 X4 and 12AT7 X2. It...
