DOUK AUDIO DAC-Q11 DAC
The Douk Audio DAC-Q11 is a unique device featuring two switchable DAC chips. It features an ESS ES9038Q2M chip and an AKM AK4493 chip. Each of these chips supports high-resolution sampling rates up to PCM 32bit 384kHz and DSD256. Users can therefore enjoy both the renowned dynamics of ESS chips and the refined tones of AKM chips.
Reference : 20721
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 22-07-2025.
Douk Audio DAC-Q11 DAC ESS9038Q2M + AK4493 32bit 384KHz DSD256
Douk Audio DAC-Q11 picture
The Douk Audio DAC-Q11 is a unique device featuring two switchable DAC chips. It features an ESS ES9038Q2M chip and an AKM AK4493 chip. Each of these chips supports high-resolution sampling rates up to PCM 32bit 384kHz and DSD256. Users can therefore enjoy both the renowned dynamics of ESS chips and the refined tones of AKM chips. For inputs, there's Toslink optical, SPDIF coaxial and a USB-B port. Outputs are divided into two groups, each comprising an RCA output and a 3.5mm jack auxiliary output. This makes it possible to switch between the DAC's 3 operating modes, allowing you to use the two different DAC chips on each set of outputs, or just one on all outputs. Added to this is a neat aesthetic, worthy of top-of-the-range devices, thanks to a transparent glass panel revealing the Douk Audio DAC-Q11 PCB and two OLED screens for displaying information on the track being played and accessing parameters.
Douk Audio DAC-Q11 operating panel
Operating modeOutput group 1Output group 2
1ES9038Q2MAK4493
2AK4493
3ES9038Q2M
Douk Audio DAC-Q11 highlights
Douk Audio DAC-Q11 overview
1Input mode display
2Sampling rate
3Volume progress bar
4Volume display (0-99)
5IR receiver
6Power / input selector / volume control
7Operating mode display
8Output group 1: Aux jack 3.5mm / RCA stereo
9Output group 2: Stereo RCA / Aux jack 3.5mm
10Coaxial input
11Toslink optical input
12USB-B input
1312V DC power port via DC jack
Product typeDAC
Dac chipsES9038Q2M
AK4493
Inputs1x USB-B
1x Coaxial
1x Toslink optical
Outputs2x Stereo RCA
2x AUX output via 3.5mm jack
Supported sample ratesUSB: PCM up to 32bit 384kHz / DSD up to DSD256
Toslink optical / Coaxial: PCM up to 24bit 192kHz
THD+N0.0003% @ 1kHz
SNR≥ 117dB
Frequency response20Hz-20KHz (±0.3dB)
USB system compatibilityWindows 7 /Windows 8 / Windows 10 / MAC / Linux
Output levelAK4493: 1.8V
ES9038Q2M: 2V
Power supply12V DC (≥1.5A) via jack DC
Dimensions155 x 125 x 42mm
Weight600g
Package1x Douk Audio DAC-Q11
1x DC 12V power adapter
1x USB-B to USB-A cable
1x Optical cable
1x Remote control
OutputJack 3.5mm
DAC / ADC ChipAK4493
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Max sampling rateDSD256
Remote ControlYes
DOUK AUDIO DAC-Q11 DAC ESS9038Q2M + AK4493 32bit 384KHz DSD256
The Douk Audio DAC-Q11 is a unique device featuring two switchable DAC chips. It features an ESS ES9038Q2M chip and an AKM AK4493 chip. Each of...
