FIIO K15 DAC Headphone Amplifier Streamer Black
The FiiO K15 is a versatile device that acts as a DAC, headphone amplifier and network audio player. Digital-to-analogue conversion is handled by a pair of AKM AK4497SVQ chips, supporting files up to PCM 32bit 768kHz and DSD512. For its amplification stage, the K15 uses a discrete Class AB architecture with MJE243G and MJE253G transistors to deliver an output power of 2x3000mW under 32Ω.
By buying this product you get 59 loyalty points
Reference : 21177
590,00 €tax incl.
491,67 € tax excl.
Shipping date: 17-11-2026.
FiiO K15 DAC AK4497SVQ Headphone Amplifier Class AB Streamer AirPlay Roon Ready 32bit 768kHz DSD512 Black
FiiO K15 : Vue de face
The FiiO K15 does not support standalone network playback (it cannot directly access streaming services) and requires the use of a third-party application for music control and playback.
FiiO K15: Dual AKM DAC
For its conversion stage, the K15 is one of the very first to incorporate a pair of the new AKM AK4497SVQ DAC chips. These chips utilise ‘VELVET SOUND’ technology, delivering exceptional levels of distortion, dynamic range and bandwidth extension. As a result, the K15 is capable of handling signals up to PCM 32-bit 768kHz and DSD512 with remarkable precision.
FiiO K15 : Double AKM DAC
FiiO K15 : Transistor
FiiO K15: Class AB amplification
For its amplification stage, the K15 features a discrete Class AB circuit, using MJE243G and MJE253G transistors and operational amplifiers in a symmetrical arrangement to deliver 2x3000mW of output power, allowing you to effortlessly drive even the most power-hungry headphones.
FiiO K15: Complete connectivity
In order to offer the best flexibility of use, the FiiO K15 incorporates a significant number of connectivity options. Thus, in addition to optical, coaxial and balanced 4.4 jack inputs, it is also capable of supporting 768kHz PCM and DSD512 streaming via USB thanks to the inclusion of an XMOS XU316 interface.
In addition, the K15 offers wireless connectivity thanks to a Bluetooth 5.1 chip compatible with LDAC, aptX, aptX LL, aptX HD, aptX Adaptive, AAC and SBC codecs. Finally, it can also act as a network receiver via RJ45 or Wi-Fi thanks to its support for AirPlay and Roon Ready protocols.
FiiO K15 in use with headphones
FiiO K15 : Balanced circuit
The entire audio chain, starting with the DAC, low-pass filter, gain control and amplification stage, uses fully balanced signal processing for excellent interference elimination, minimal distortion and high dynamic range.
FiiO K15 : Internal circuit diagram
FiiO K15 : Switching power supply
FiiO K15: Low-noise power supply
The K15 benefits from a low-noise 30W switching power supply. This is coupled with 14 low-dropout regulators (LDO) and numerous ELNA and Nichicon capacitors to ensure that each component of the K15 receives a stable power supply free of any unwanted artefacts.
Furthermore, in order to minimise crosstalk, the digital and analogue power supply stages are physically separated and spread across three different PCBs. Finally, the K15 also features an external DC power input, allowing you to connect it to an external linear power supply of your choice if desired.
FiiO K15: Internal femtosecond clocks
The K15 also incorporates two ACCUSILICON femtosecond clocks at its core, effectively reducing noise related to phase errors in the final audio signal.
FiiO K15: Processor and microcontroller
FiiO K15: X2000 processor
In order to offer instant responsiveness, the K15 is based on a solution combining an Ingenic X2000 processor and an ESP32-S3 microcontroller, ensuring stable and fast signal processing while guaranteeing a perfectly smooth user experience.
FiiO K15: Retro aesthetics
In addition to its technical excellence, the K15 also boasts a retro aesthetic that prioritises ease of use and practicality. The front panel features various control knobs and a 3.93-inch LCD touchscreen, while the aluminium body has numerous grilles to ensure excellent heat dissipation.
FiiO K15 : Front view
FiiO K15: 10-band equaliser
For its K15, FiiO has developed a 10-band equaliser. This allows you to customise the frequency response with excellent precision, as well as export, import, share and save equalisation curves. Whether you choose to use the recommended settings or share your own settings online with other enthusiasts, it's very easy to access them, either through the FiiO Control app or the online version.
FiiO K15 : 10-band equaliser
Product typeDAC
Headphone amplifier
Streamer
Inputs1x Stereo RCA
1x Optical Toslink
1x Coaxial
2x USB-C
1x USB-A
1x RJ45
1x Jack 4.4mm
Bluetooth 5.1
WiFi dual-band 2.4G/5G
1x Balanced stereo XLR
1x Single-ended 6.35mm headphone jack output
1x Balanced 4.4mm headphone jack output
1x Balanced 4-pin XLR headphone output
MicrocontrollerESP32-S3
CPUX2000
DAC2x AK4497SVQ
USB interfaceXMOS XU316
Headphone amplificationMJE243G/253G transistors
Supported sampling ratesUSB: PCM up to 32bit 768kHz / DSD up to DSD512
Coaxial: PCM up to 24bit 192kHz / DSD64
Optical: PCM up to 24bit 96kHz
Streaming: PCM up to 32bit 384kHz / DSD up to DSD256
Local playback: PCM up to 32bit 384kHz / DSD up to DSD256
Gain modeLow gain
Medium gain
Hight gain
Super hight gain
Ultra hight gain
Adaptive impedanceSingle-ended: 8~150Ω
Balanced: 8~350Ω
ScreenTouchscreen LCD 3.93"
Supported Bluetooth codecsSBC / AAC / aptX / aptX LL / aptX HD / aptX Adaptive / LDAC
Single-ended headphone output specifications (Ultra High Gain)
Output power1400mW+1400mW (16Ω, THD+N<1%)
1400mW+1400mW (32Ω, THD+N<1%)
180mW+180mW (300Ω , THD+N<1%)
Frequency response20Hz-20kHz (<-0.2dB)
20Hz-80kHz (<-2.8dB)
Crosstalk≥ 76dB (1kHz @ 32Ω)
Total harmonic distortion more noise (THD+N)< 0.00054% (1kHz/-12dB @ 32Ω)
Signal-to-noise ratio (SNR)≥ 122dB (A-weighted)
Output impedance< 1Ω (32Ω)
Output level> 20.6Vp-p
Noise floor< 5.3μV (A-weighted)
Single-ended headphone output specifications (Super High Gain)
760mW+760mW (32Ω, THD+N<1%)
90mW+90mW (300Ω , THD+N<1%)
Crosstalk≥ 76dB (1kHz@32Ω)
Total harmonic distortion more noise (THD+N)< 0.00058% (1kHz/-10dB @ 32Ω)
Signal-to-noise ratio (SNR)≥ 119dB (A-weighted)
Impédance de sortie< 1Ω (32Ω)
Output level> 14.6Vp-p
Single-ended line output specifications
Total harmonic distortion more noise (THD+N)< 0.00071% (1kHz/-11dB @ 10kΩ)
Crosstalk≥ 119dB (1kHz @ 10kΩ)
Noise floor< 2.6μV (A-weighted)
Output level2.4Vrms (1kHz @ 10kΩ)
Balanced headphone output specifications (Ultra High Gain)
3000mW+3000mW (32Ω, THD+N<1%)
700mW+700mW (300Ω , THD+N<1%)
Crosstalk≥ 116dB (1kHz @ 32Ω)
Total harmonic distortion more noise (THD+N)< 0.00059% (1kHz/-13dB @ 32Ω)
Signal-to-noise ratio (SNR)≥ 120dB (A-weighted)
Impédance de sortie< 1.5Ω (32Ω)
Output level> 41Vp-p
Noise floor< 9.5μV (A-weighted)
Balanced headphone output specifications (Super High Gain)
2800mW+2800mW (32Ω, THD+N<1%)
350mW+350mW (300Ω , THD+N<1%)
Total harmonic distortion more noise (THD+N)< 0.00054% (1kHz/-9dB @ 32Ω)
Output level> 29Vp-p
Balanced line output specifications
Total harmonic distortion more noise (THD+N)< 0.00055% (1kHz/-8dB @ 10kΩ)
Crosstalk≥117dB (1kHz@10kΩ)
Noise floor< 3.3μV (A-weighted)
Output level4.8Vrms (1kHz @ 10kΩ)
Power supply100-240V AC 50/60Hz
12V DC 2.5A
Dimensions244.6 x 213 x 66.8mm
Weight2.1kg
Package1x FiiO K15
1x Remote control
1x Power cord
2x USB-A to USB-C cable
1x Fuse
1x 3.5mm to 6.35mm jack adapter
1x Cap for XLR
InputRJ45
InputJack 4.4mm
InputWiFi
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipAK4497SVQ
Max sampling rateDSD512
Max sampling rate768kHz
ClassClass A / AB
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
FIIO K15 DAC AK4497SVQ Headphone Amplifier Class AB Streamer AirPlay Roon Ready 32bit 768kHz DSD512 Black
The FiiO K15 is a versatile device that acts as a DAC, headphone amplifier and network audio player. Digital-to-analogue conversion is handled by a...
