Décidément une marque offrant des produits avec un rapport qualité/prix déroutant. J'utilise un ampli de cette marque depuis 2017 pour mon streaming Qobuz et mes B&W. Très content
DAC Amplificateur Casque ES9038Q2M XMOS Bluetooth 5.0 CSR8675 32bit 768kHz DSD512
Featuring an excellent 32-bit ES9038Q2M digital-to-analog conversion chip, the DAC FX-Audio D01 offers excellent audio performance with a wide dynamic range, low distortion, and jitter reduction. The USB interface uses a second-generation XMOS XU208 chip, supporting high sample rates up to 32bit 768kHz PCM and DSD512 with a custom Thesycon driver.
The headphone amplification stage is entrusted to a TI TPA6120A2 chip, perfectly stable and also ensuring low distortion. Its power allows it to accompany headphones with impedance ranging from 16 to 300Ω.
Finally, in terms of connectors, the D01 benefits from a complete panel of inputs to adapt to all audio systems. USB-B, Toslink Optics, Coaxial but also Bluetooth connectivity allowing you to broadcast your music remotely, from your smartphone for example. The headphone output on the front of the device is in 6.35mm jack format and the rear provides a stereo RCA line output.
Product type | DAC Headphone amplifier |
Inputs | Bluetooth 5.0 1x USB-B 1x Optical 1x Coaxial |
Outputs | 1x Jack 6.35mm Headphone output 1x Stereo RCA line output |
Microcontroller | STM32 |
DAC Chip | ES9038Q2M |
USB Interface | XMOS XU208 |
Amplification chiip | TPA6120ADWPR |
AOP | LME49720NA |
Bluetooth chip | CSR8675 |
Line output level | 2Vrms @ 0dBFS |
Distortion | < 0.002% @ 1kHz |
SNR | 115dB @ 1kHz |
Dynamic range | 115dB @ 1kHz |
Sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Coaxial / optical : PCM up to 24bit 192kHz Bluetooth : PCM up to 24bit 96kHz |
Power output | 2x 400mW @ 32Ω, THD+N < 1% 2x 90mW @ 300Ω, THD+N < 1% |
Headphone amp distortion | < 0.004% @ 1kHz |
Headphone amp SNR | > 110dB @ 1kHz |
Frequency response | 20Hz - 20kHz @ +0, -0.5dB |
Amp impedance | 16-300Ω |
Power supply | 12VDC 1A (included) |
Body material | Aluminum |
Color | Black |
Dimensions | 114 x 178 x 33mm |
Weight | 470g |
Package | 1x x D01 1x Power Adapter 1x USB-A to USB-B cable 1x Bluetooth antenna |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | Jack 6.35mm |
Output | RCA |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Class | Class D / T |
Networking | No |
Remote Control | No |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bertrand T.
David G.
