SMSL DL100 DAC 4x CS43131 Headphone Amplifier
With the DL100, SMSL offers us a high-performance DAC incorporating quality components such as a combo of 4 Cirrus Logic CS43131 chips, an XMOS XU-316 USB interface and a Qualcomm Bluetooth receiver chip. The DL100 is capable of decoding high sampling rates, up to PCM 32bit 768kHz, DSD256 and DoP 64. It is also capable of decoding MQA files up to MQA-CD. But that's not all: the DL100 also doubles up as a headphone amplifier with its two balanced 6.35mm and 4.4mm jack outputs and dedicated amplifier circuit comprising 3 OPA1612a amplifiers.
Reference : 19486
215,00 €tax incl.
179,17 € tax excl.
Shipping date: 22-07-2025.
SMSL DL100 DAC CS43131*4 Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA-CD
SMSL DL100 : Front view
CS43131 CAD chip
SMSL DL100 : 4 DAC chips
SMSL's DL100 is a device capable of decoding up to PCM 32bit 768kHz, DSD256 without prior conversion and in DoP64 for optical and coaxial inputs. This is thanks to four Cirrus Logic CS43131 DAC chips working together to give you the cleanest, most accurate conversion possible.
SMSL DL100 : USB XMOS XU316
The USB XMOS XU316 interface on a USB-C port can operate in 2.0 or 1.1 mode. The 2.0 interface requires a driver and supports 32bit 768kHz and DSD256. The 1.1 interface supports up to 24bits 96kHz without a driver, so you can connect a wide range of sources such as consoles (PS5, XBOX, Switch, etc), your TV or Android devices.
XMOS XU316 USB chip
SMSL DL100 : Bluetooth 5.1
A Qualcomm Bluetooth receiver chip enables transmission of LDAC 24bit/96kHz, aptX HD, aptX, SBC and ACC formats.
SMSL DL100 : Headphone outputs
SMSL DL100 : Dedicated amplifier circuit
On the front of the DL100, there are two headphone outputs. A 6.35mm jack output and a balanced 4.4mm jack output. Thanks to a dedicated amplification circuit comprising three OPA1612a chips, the DL100 boasts headphone output power of 2x3W at 16Ω.
SMSL DL100 : Remote control
An infrared remote control allows you to operate the DL100 remotely for a more enjoyable listening experience. You can adjust all the settings available in the DL100 menu.
SMSL DL100 : remote control
SMSL DL100 : 5 PCM filters
The DL100 incorporates 5 filters that can be used during the conversion of a PCM signal to an analogue signal. Each filter acts on high frequencies above 20 kHz.
SMSL DL100 : filtres PCM
SMSL DL100 : Connectors
16.35mm headphone output
2Balanced 4.4mm headphone output
3Display
4Bluetooth antenna
5Multifunction knob
6Power supply IEC
7USB-C input
8HDMI-ARC input
9Optical Toslink input
10Coaxial SPDIF input
11Balanced XLR stereo output
12Stereo RCA output
Test du SMSL DL100 par AudioScienceReview
DL100 provides some form factor changes and inclusion of HDMI ARC. Performance is more than excellent in every area, making for a compelling package despite its attractive price. I especially like its high current drive for headphones that have low impedance. I am happy to recommend the SMSL DL100 dac and headphone amplifier. "
Product typeDAC
Headphone amplifier
DAC chip4x CS43131
OPA3x OPA1612a
Inputs1x USB-C
1x Optical Toslink
1x Coaxial SPDIF
1x HDMI ARC
Bluetooth
Outputs1x RCA stereo
1x Stereo XLR
Headphone output 6.35mm jack
Headphone output 4.4mm jack
Output levelRCA : 2.5Vrms
XLR : 5.2Vrms
HPA : 7.5Vrms
Headphone output power2x 3W @16Ω
2x 1.5W @32Ω
total harmonic distortion more noise (THD+N)Line outputs : 0.00009% (-120dB)
Headphone outputs : 0.0001% (-115dB)
Dynamic rangeRCA : 126dB
XLR : 132dB
HPA : 126dB
Signal-to-noise ratio (SNR)RCA : 126dB
XLR : 132dB
HPA : 126dB
Output impedanceLine outputs : 100Ω
Headphone outputs : près de 0Ω
USB transmission protocol1.1 et 2.0 (Asynchronous)
USB compatibilityWindows 7/8/9/10/11 (with driver)
Android
Max OSX 10.6 and higher
Linux (without driver)
Bit depthUSB : 16-32bits
Optical / SPDIF: 16-24bits
Supported sample ratesUSB : PCM 32bits 768kHz, native DSD up to DSD256
Optique et coaxial : PCM 24bits 192kHz and DoP64
Bluetooth5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Power consumption< 30W
Standby power consumption< 0.5W
Dimensions196 x 31 x 206mm
Weight1.05kg
Package1x SMSL DL100
1x Remote control
1x Power cable
InputHDMI ARC
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipCS43131
Max sampling rate768kHz
Max sampling rateDSD256
ClassN/A
Remote ControlYes
2 reviews
Bonne surprise
J'ai mis un peu de temps à poster l'avis, le temps de tester plus longuement.
Actuellement installé sur un LD systems Dave 10 g4x, téléviseur Panasonic, écoute Spotify premium, Netflix, pièce traitée (bass trap accordée, panneaux absorbeurs et déflecteurs). Le Dave 10 s'est réveillé, et bien réveillé. L'aération, instruments à leur place, l'image 3D et profondeur m'a surpris. Je pensais que le résultat serait bien en deçà de ce que j'ai pu lire suite à l'avis du premier acheteur et de l'avis d'amir. Ce dac est finalement bien placé dans sa gamme de prix. Pas de souffle sur le Dave pouvant sortir 110 db dans le salon. Sans mesures, la distorsion à l'air maitrisée. Sur les films et streaming, le son ne déborde pas, l'intimité ou la brutalité est parfaitement retranscrit. Le dialogue se passe largement de voie centrale (je possédais une salle HC dédiée avec dirac), on sait bien qu'en config 2.1 le placement est primordial. Je n'ai pas eu besoin de me torturer l'esprit (le traitement sonore y joue forcément). Le mariage avec le Dave 10 était osé, bien m'en a pris.
La sortie casque est testée que sur le jack 6.3mm, avec un akg 551 tweaké pour la musique, fermeté du signal originel aux petits oignons, aucunes sibilances, sauf dans les limites auditives où la distorsion se fait clairement sentir. Test nº2 sur superlux hd 681 evo cheap et tweaké également pour les films uniquement (le akg est orienté hifi-limite monitoring suite au tweak) je ne reconnais pas mes modifications, les dialogues se recentrent, les effets sont à leur place et ne partent pas dans tous les sens, ils collent précisément là où doit être l'effet. Les parties musicales prennent une belle ampleur. Donc ravi de ce dac qui fais vraiment le job, plus que je pensais.
Mon avis n'engage que moi dans une pièce traitée.
This review has been posted for SMSL DL100 DAC 4x CS43131 Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA-CD
Un tout en un pour un petit prix (HDMI Arc en bonus)
J'ai mis 5 étoiles non pas pour ses qualités sonores qui sont bonnes sans être extraordinaire, mais pour son côté couteau suisse à un prix vraiment abordable.
Voici ce qu'il inclut :
Sorties XLR (symétriques), RCA, casque 6,35mm et 4,4mm
Entrées : HDMI Arc, optique, coaxial, USB type C (1.0 et 2.0), Bluetooth (Aptx et LDAC)
Tout cela aux alentours de 200€, rien à redire.
Alors certes, pas de DAC ESS ni AKM, mais 4 puces Cirrus Logic CS43131 (2 par canal) qu'on retrouve dans des mini-DAC portables.
Des Op Amp de qualité, mais en quantité moindre, 3 OPA1612a qui permettent une amplification plus que correcte et puissante ( 2x 3W en 16Ω pour la sortie casque 4.4mm). Certes, il y a eu des économies, l'écran LCD a un effet "vintage" (comme nos anciens réveils), mais reste lisible. Certes le son n'est pas le meilleur du marché, mais n'est en aucune façon mauvais, bien au contraire et les mesures plus que correctes en attestent.
Je le conseille principalement à ceux qui désirent écouter au casque sur la TV (grâce au HDMI Arc meilleur que le câble optique (toslink)) et y brancher via les sorties XLR deux enceintes actives en stéréo, puis pourquoi pas un sub sur la sortie RCA.
S'il coûtait le double, il perdrait 2 étoiles, mais c'est justement sur le prix qu'il est imbattable. Une fois de plus, SMSL parvient à sortir un produit au rapport qualité/prix de folie.
PS : Le seul DAC tout en un qui propose les mêmes fonctionnalités dont le HDMI Arc est le FiiO K19 à 1400€, soit quasiment sept fois plus cher. Il y a également le SMS DO200 PRO, mais il n'y a pas de sorties casque.
With the DL100, SMSL offers us a high-performance DAC incorporating quality components such as a combo of 4 Cirrus Logic CS43131 chips, an XMOS...
