By buying this product you get 54 loyalty points
SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the latest ESS ES9039MSPro chip, an XMOS XU316 USB interface, 11 OPA 1612A and the latest generation Qualcomm QCC5125 Bluetooth chip. To complete the package, an MQA decoder is integrated into the DO400, enabling it to decode high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA-CD. Headphone amplifier performance is also very good, thanks to the use of a PLFC circuit. The DO400's complete and varied connectivity will adapt to a wide range of configurations and input sources. SMSL has opted for an internal symmetrical circuit design, and the exterior features a large screen and a number of small aesthetic details, making this a pleasing-looking device.
The DO400 incorporates ESS's very high-performance ES9039MSPro DAC chip. This 32-bit, 8-channel chip is based on Hyperstream IV structure technology. It enables the DO400 to decode up to 32bit 768kHz PCM and DSD up to DSD512. It also accepts MQA streams.
A 16-core XMOS XU316 USB interface is integrated into the DO400, enabling it to process high-resolution streams (PCM 32bit 768kHz and DSD512) via its USB-B input port. This may be ideal for users wishing to use their computer as a source device. The interface is coupled with no less than 11 AOP1612A.
A Qualcomm QCC5125 chip enables the SMSL DO400 to support AAC, SBC, aptX, aptX HD and LDAC codecs. So you can enjoy high-resolution files in wireless transmission.
On the front of the DO400 are three headphone outputs: a balanced 4-pin XLR headphone output, a balanced 4.4mm jack output and an unbalanced 6.35mm jack output. The headphone amplifier circuit is an ultra-low distortion 4-channel PLFC circuit. It delivers over 2W output power with less than 0.0001% distortion at less than 16 ohm load. The DO400 can therefore be adapted to all types of headphones, thanks to its varied connectivity and high output power; 2x 6000mW / 16Ω, 2x 3000mW / 32Ω, 2x 700mW / 300Ω and 2x 350mW / 600Ω.
The DO400's MQA decoder enables it to support MQA-CD streams via its coaxial, AES and Toslink optical inputs. This DAC therefore offers the possibility of enjoying professional audio quality, with retransmission as close as possible to the original sound recorded and edited in studio.
SMSL has specially designed a regulated linear power supply for its DO400 DAC. This low-noise power supply powers the DO400's discrete components. Multiple low-noise power supplies are also present for the analog part of the DAC.
The DO400's remote control provides access to all basic functions such as volume control, play/pause/previous/next functions and input source selection.
1 | Screen |
2 | Bluetooth antenna |
3 | Volume control |
4 | 6.35mm jack unbalanced headphone output |
5 | 4.4mm jack balanced headphone output |
6 | XLR 4-pin headphone output |
7 | Unbalanced stereo RCA output |
8 | Balanced stereo XLR output |
9 | AES/EBU input |
10 | Bluetooth antenna connector |
11 | I2S input via HDMI |
12 | Toslink optical input |
13 | Coaxial input |
14 | USB-B input |
15 | IEC power connector |
16 | Fuse slot |
17 | Power switch |
Product type | DAC Headphone amplifier |
Input | 1x USB 1x Coaxial 1x AES/EBU 1x Optical Toslink 1x I2S via HDMI Bluetooth |
Outputs | 1x Stereo RCA analog output 1x XLR stereo balanced output 1x XLR 4-pin balanced headphone output 1x 4.4mm balanced headphone jack output 1x 6.35mm unbalanced headphone jack output |
Supported sample rates | PCM 32bit 768kHz, DoP64, DoP256 DSD512, MQA, MQA-CD |
Output level | XLR: 5.2Vrms RCA: 2.5Vrms |
Headphone output power | 2x 6000mW / 16Ω 2x 3000mW / 32Ω 2x 700mW / 300Ω 2x 350mW / 600Ω |
THD+N | XLR: 0.00005% (-125dB, unweighted) RCA: 0.00007% (-123dB, unweighted) HPA: 0.00009% (-120dB, unweighted) |
Dynamic range | XLR: 133dB RCA: 128dB HPA: 126dB |
SNR | XLR: 133dB RCA: 128dB HPA: 126dB |
Output impedance | Line outputs : 100Ω Headphone outputs : near 0Ω |
Headphone output gain | Balanced: +20dB Unbalanced: +14dB |
USB transmission | 2.0 asynchronous |
USB compatibility | Windows 7/8/9/10/11 (with driver) Mac OS 10.6 Linux |
MQA decoding | MQA : USB, Optical Toslink, Coaxial, AES/EBU MQA-CD : Optical Toslink, Coaxial, AES/EBU |
Supported bluetooth codecs | AAC, SBC, aptX, aptX HD, et LDAC |
Power consumption | < 40W |
Standbye power consumption | < 0.5W |
Color | Silver |
Dimensions | 245 x 186 x 42mm |
Weight | 1.45kg |
Package | 1x DAC / Headphone amplifier DO400 SMSL 1x Power cable 1x USB-A to USB-B cable 1x Bluetooth antenna 1x Remote control |
Input | USB |
Input | Optical |
Input | I2S via HDMI |
Input | SPDIF |
Input | Bluetooth |
Input | AES/EBU |
Output | Jack 4.4mm |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | Yes |
