With the DS200, SMSL presents a compact DAC and headphone amplifier with a retro-futuristic aesthetic. It's equipped with a Cirrus Logic CS43131 DAC chip combined with a 3rd-generation XMOS XU-316 chip, enabling it to support sampling rates up to PCM up to 32bit 768kHz and DSD up to DSD256, with a total harmonic distortion of just 0.00019%. Its coaxial, USB, and optical inputs and Bluetooth 5.1 connectivity make it a flexible device, capable of integrating into a wide range of configurations.
1 | Mode selector |
2 | Power indicator light |
3 | Indicator light for active mode |
4 | Mood light |
5 | 3.5mm jack headphone output |
6 | 4.4mm jack headphone output |
7 | Gain selector |
8 | Output selector |
9 | Volume control |
10 | Bluetooth antenna |
11 | Line output |
12 | Coaxial input |
13 | Optical input |
14 | Auxiliary USB-C power supply |
15 | USB-C input |
Product type | DAC Headphone Amplifier |
Inputs | 1x Optical Toslink 1x Coaxial 1x USB-C Bluetooth |
Outputs | 1x Single-ended 3.5mm jack headphone output 1x Balanced 4.4mm jack headphone output 1x Stereo line output |
DAC Chip | CS43131 |
Supported sampling rates | USB : PCM up to 768kHz / DSD up to DSD256 Optical / Coaxial : PCM up to 192kHz / DSD64 (DoP) |
Output level | 2.0Vrms |
Dynamic range | 127dB |
Signal-to-noise ratio | 127dB |
Total harmonic distortion more noise (THD+N) | < 0.1W |
Bluetooth version | 5.1 |
Supported Bluetooth codec | SBC |
Power supply voltage | 5V DC |
Energy consumption | Standby : < 0.1W In use : 3W |
Weight | 346g |
Dimensions | 70 x 70 x 113mm |
Color | Silver |
Package | 1x SMSL DS200 |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
Output | RCA |
DAC / ADC Chip | CS43131 |
Max sampling rate | DSD256 |
Max sampling rate | 768kHz |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | No |
