SMSL RAW-MDA1 DAC
The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA.
4.8 / 5
Reference : 19420
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 05-09-2025.
SMSL RAW-MDA1DAC 2xES9039Q2M / Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA
Photo of SMSL RAW-MDA1
The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA. Added to this is Bluetooth 5.1 functionality thanks to a Qualcomm receiver chip supporting SBC, AAC, aptX, aptX HD and LDAC codecs. The RAW-MDA1 also benefits from an independent headphone amplification circuit for consistent output power in balanced 4.4mm jack or 6.35mm jack. Several digital and optical inputs are available: USB-C, 2x SPDIF Coaxial, 2x Optical Toslink, complemented by a stereo RCA line output and a balanced XLR output.
SMSL RAW-MDA1: XMOS XU316 USB interface and ES9039Q2M dual DAC
The SMSL RAW-MDA1 DAC supports high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512 thanks to its XMOS XU316 USB interface and two ES9039Q2M DAC chips. The RAW-MDA1's balanced operation offers excellent performance, with a dynamic range of 132dB and a THD+N of 0.00005%.
Photo of XMOS interface and ES9039Q2M DAC chipset
SMSL RAW-MDA1 MQA decoding
SMSL RAW-MDA1: MQA decoder
The RAW-MDA1 DAC benefits from the most advanced MQA decoding technology, enabling it to perform complete expansion of MQA and MQA-CD files.
SMSL RAW-MDA1: Bluetooth 5.1
The RAW-MDA1 DAC is equipped with a Qualcomm Bluetooth receiver chip supporting the following high-definition codecs: SBC, AAC, aptX, aptX HD, and LDAC. The Bluetooth LDAC codec enables stream transfer at up to 24bit 96kHz.
Bluetooth 5.1
An independent amplifier circuit
SMSL RAW-MDA1: independent headphone amplifier circuit
An independent headphone amplifier circuit enables the SMSL RAW-MDA1 to achieve an output power of up to 2x 2.5W into 16 Ohm and up to 1.7W into 32 Ohm. The RAW-MDA1 is therefore able to drive many of the headphones available on the market.
SMSL RAW-MDA1: 2 USB modes
The RAW-MDA1's USB-C input operates in both USB1.1 and USB2.0. This is convenient for those wishing to use this DAC with video game consoles such as PlayStation or Nintendo Switch. USB 2.0 supports 32bit 768kHz PCM streams via a driver, while USB1.1 supports 24bit 96kHz PCM streams without a driver.
USB1.1 and USB2.0 protocols
Des composants High-end
OPA1612A
6x OPA1612A
The SMSL RAW-MDA1 features no less than 6 AOP1612A.
Optimized clock circuit
The SMSL RAW-MDA1's clock circuit reduces jitter considerably.
Low-noise power supply
The SMSL RAW-MDA1 features a low-noise power supply delivering clean, reliable current.
SMSL RAW-MDA1 Overview
1Jack 6.35mm headphone output
2Balanced Jack 4.4mm headphone output
3Display
4Standby LED indicator
5IR remote control receiver
6Multifunction buttons / volume control
7XLR balanced stereo output
8RCA stereo output
92x SPDIF coaxial input
102x Toslink optical input
11Bluetooth antenna
12USB-C input
13IEC power supply
Test du SMSL RAW-MDA 1 par AudioScienceReview
" The RAW-MDA 1 aims high and achieves it across the board despite its very reasonable price. It is good looking, compact and easy to operate. Some of this we expect from SMSL but the total package is a step forward, as difficult as that may have seemed. I am happy to recommend the SMSL RAW-MDA 1. "
Product typeDAC / Headphone amplifier
DAC chips2x ES9039Q2M
OPA6x OPA1612A
Inputs1x USB-C
2x SPDIF coaxial
2x Optical Toslink
Bluetooth 5.1
Outputs1x Balanced XLR stereo
1x Single-ended RCA stereo
Supported sample ratesUSB: PCM 32bit 768kHz,DSD DoP256, DSD natif DSD512 and MQA
Coaxial SPDIF and Optical Toslink: PCM 24bit 192kHz, DSD DoP64, MQA
THD+N0.00005% (-124dB non-weighted)
Output levelXLR: 5.2Vrms
RCA: 2.5Vrms
Headphone outputs: 8.2Vrms
Headphone output power2x 2.5W @ 16 Ohms
2x 1.7W @ 32 Ohms
Output impedanceLine outputs: 100 Ohms
Headphone outputs: close to 0 Ohms
Dynamic rangeXLR: 132dB
RCA: 127dB
Headphone outputs: 122dB
SNRXLR: 132dB
RCA: 127dB
USB transmissionAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (avec driver)
MAC SOX10.6 et plus (sans driver)
Linux (sans driver)
Bluetooth versionBluetooth 5.1
Supported bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Energy consumption< 30W
Standby: < 0.5W
Dimensions189 x 45 x 179mm
Weight1.02kg
Package1x SMSL RAW-MDA1 DAC
1x USB cable
1x Bluetooth antenna
1x RC-8C remote control
1x Power cable
DAC / ADC ChipES9039Q2M
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
5 reviews
Ne pas choisir la livraison par DPD
Audiophonics a été très réactif quant à la livraison mais DPD n'a pas respecté les délais nis mon colis il est arrivé dans un état abominable heureusement qu'il est bien protégé.
sinon le DAC et fantastique !
This review has been posted for SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA
Great product!
For the price this thing is great! It's well build, looks good and functions as promised.
Menus are very clear and settings are easy to changes according your personal needs.
The remote also works better then the one from the Topping product I had before.
The display is clear and informative. (brightness is high, so you can set it to the lowest level and it is still readable from a good distance)
But better still: objectively it lives up to the specs the manufacturer shows on the product page. (https://www.audiosciencereview.com/forum/index.php?threads/smsl-raw-mda-1-dac-headphone-amp-review.56430/) It does not sound. It just transforms from the digital domain to the analog and amplifies (actually it attenuates) the signal without any audible artifacts.
Excellent DAC
I am very pleased with the purchase, the DAC is very perfomant
Bonus pour les connectiques
DAC équipé de 2 entrées Coax et 2 entrées Spdif, ce qui est à mon avis un vrai plus. Qualité sonore vraiment excellente et bluffante à ce tarif. La combinaison de ces deux points en fait une alternative très sérieuse face à des appareils 2 à 3 fois plus onéreux. Je recommande vivement
Fait aussi bien (voire mieux) que des DAC avec ESS ES9038Pro
Excepté l'absence d'une Entrée HDMI Arc (que j'aurais souhaité, obligé de me rabattre sur le moins qualitatif SMSL DL100 pour le coin TV), le choix de mettre deux puces ESS ES9039Q2M (pour chaque canal) à la place d'une ESS ES9039Pro (le prix serait aisément doublé) et pas de PEQ intégré (une égalisation paramétrique), tout est parfait. Les mesures ne me contredisent pas.
J'avais peur que l'amplification casque (6,3 et 4,4mm) soient en retrait, que nenni, c'est excellent et puissant. Venant d'un Xonar Essence One amélioré avec des Opamp de qualité, j'entends des micro détails jusque là masqués. Un son précis, avec une bonne ouverture, détaillé sur l'ensemble du spectre, dynamique et de bonnes basses percutantes (juste ce qu'il faut). Je n'ai pas essayé de DAC à 1000€ ou plus, mais la différence doit être minime.
En toute honnêteté, ce DAC avec sortie casque vaut largement le SMSL M500 ou autre DAC tout intégré à base d'ESS ES9038Pro.
Un excellent rapport qualité/prix qui sera l'investissement idéal pour les mélomanes/audiophiles/homestudistes modestes et intelligents.
+ Un superbe son (sorties XLR, RCA et casque)
+ Tout est quasiment inclus (Bluetooth, MQA, MQA-CD)
+ Une taille modérée, s'insère partout
- Pas d'HDMI Arc
- Des puces DAC moins chères mais qui sont plus que suffisantes
- Pas de PEQ (égalisation paramétrique incluse) mais des filtres pour colorer le son.
 (3)
The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to...
