SMSL SANSKRIT 10Th MKII DAC 32bit / 768kHz DSD512 USB XMOS AK4493 Red
This is the MKII version of SMSL Sanskrit 10th anniversary edition : an original and aesthetic device with extremely complete functionalities at a very affordable price.
4.9 / 5
Reference : 13401
115,00 €tax incl.
95,83 € tax excl.
To operate the remote control with Sanskrit, it is necessary to press the "C" key on the remote control.
SMSL Sanskrit 10th Anniversary Edition MKII
DAC XMOS, AK4493 DSD512 PCM768kHz
Compact and versatile DAC DSD256 / PCM 384kHz. Detector integrated tilt.
This is the MKII version of SMSL Sanskrit 10th anniversary edition: an original and aesthetic device with extremely comprehensive features for a very affordable price. It works with a conversion chip AKM AK4493, a USB interface XMOS and its construction follows proven circuits in high fidelity audio.
It has a rotating screen (like a smartphone) that allows it to be installed on both sides (Length / Width) without losing legibility. A second novelty lays in its power supply since the device has two USB inputs, so as to separate the power supply from data and gain in sound clarity.
SMSL SANSKRIT 10Th standard
DAC
AK4493
AK4490
THD+N
0.0002%
0.0005%
SNR
120dB
118dB
Sampling Rate
PCM : 768kHz / DSD512
PCM : 384kHz / DSD256
DAC tilt
Definitely designed for the high-quality sound, Sanskrit is able to decode DSD formats (DSD512 max) and PCM (768kHz).
It has all the necessary inputs to meet a complex installation and can simultaneously connect a digital audio source (computer, smartphone OTG, media center), a TV and a gaming station thanks to USB / Coaxial and Optics ports.
To facilitate installation in any type of environment, Sanskrit can be placed either on its edge or along its length. Best of all, the device has an integrated sensor allowing it to automatically orient the screen in your reading direction.
High quality audio components
DAC USB coaxial optical
The digital / analog decoding is made possible by a chip AK4493 AKM. This advanced audio component preserves transparency, finesse and details in the sound reproduction.
The AK4490 operates together with a XMOS asynchronous USB interface thant is famous for its native support of DSD streams. These chips are integrated in Sanskrit with a procession of proven electronic components from the power-supply units to NDK ultra low phase noise clocks.
With this choice of ambitious components (especially in this price range), DAC Sanskrit delivers crystal clear sound with extremely low distortion (THD + N 0.0002%), wide dynamic range of 119dB and comfortable SNR of 120dB.
Volume hardware and remote control
DAC remote volume
Finally, Sanskrit has two features that are found usually in larger, more complex and more expensive devices:
- A hardware volume control (does not damage the resolution in digital audio stream). This feature allows to connect Sanskrit directly to a power amplifier without necessarily having to go through a volume controller preamplifier.
- A remote control support. Every function can be driven remotely such as : raise / lower the volume, alternate sources ...
Double USB input
Rear Facade Sanskrit SMSL
Sanskrit is USB-powered via a Micro-USB input on its back cover.
To isolate the audio signal from the noise coming along the power supply, two USB entries are present: one dedicated to data only and the other dedicated exclusively to the power supply. Thanks to this configuration, the audio source is not in charge of powering the DAC - which is generally poor in this function - and it is quite possible to connect this USB input to a real regulated linear power supply that meets the audiophile standards to maximize your listening experience.
Review by Audio Science Review
These mini "pocket" DACs are changing the game with their excellent performance and budget prices. There is really no excuse to use sub-par DACs or spend orders of magnitude for boutique DACs with far worse performance.
 test by the measurement forum Audio Science Review
Quobuzissime award for Sanskrit 10th anniversary
"S.M.S.L offers a visually beautiful digital to analog converter with superb sound performance, among the moste beautiful sounds we heard."
Test Qobuz
1 - I/R Receiver
2 - Display (auto pitch)
3 - Power / selection button
4 - Analog Out RCA Stereo
5 - Coaxial Input
6 - Optical Input
7 - USB input (DATA)
8 - USB input (Power)
TypeDAC
Volume ControlYes
Output Level2.2Vrms
THD + N0.0002%
Dynamic range119dB
Signal / N ratio120dB
USB compatibilityWindows 7/8 / 8.1 / 10
Mac OS X10.6 and higher
Linux
BIT DepthUSB: 1-32bit
Coaxial / Optical: 1-24bit
Sample rateUSB PCM: 44.1 - 768kHz
USB DSD: DSD512
Optical / Coaxial: 32-192kHz
Power supplyMicro-USB 5VDC (Not Included)
Power consumption1.5W
Quiescent currentLess than 0.1W
Dimensions75 x 45 x 144mm (width / height / depth)
Weight300g
Package Contents
1xDAC Sanskrit 10th anniversary MKII
1xRemote control (Press "C" to activate the remote control)
1xUSB-A to Micro-USB cable 1.1m
8xsilicone feet
DAC / ADC ChipAK4493EQ
Max sampling rate768kHz
ColorOther
Remote ControlYes
20 reviews
Très bon petit dac au look sympa avec un rendu precis sans être trop froid .
Il fonctionne aussi bien avec mon pc windows 10 et ma invidia shield .
" Pour les petits budgets qui veulent quand même de la qualité" c'est le bon choix !
This review has been posted for SMSL SANSKRIT 10Th MKII DAC 32bit / 768kHz DSD512 USB XMOS AK4493 Red
Très bien
Je confirme les avis élogieux généraux : Petit Dac AKM 4493 donnant une grande qualité d'écoute ...de l’ampleur , excellente séparation des instruments , son détaillé , Basses amples ...une grosse différence avec le Dac intégré à mon Denon AVR -1603 et un net mieux qu'un petit Dac Ess9018 usb (Hifime) pourtant assez excellent .
Pour ce prix en plus , oui je recommande !
Good value.
Upgraded from my NAD D1050 (CS4398) that tragically died.
This unit does everything just as good or better.
- for no USB-C
Aucun problème après 1 an d'utilisation polyvalente
Je n'ai pas d'expérience sur d'autres cartes son. Ce produit me sert depuis 1 an sans avoir jamais eu de soucis. Je l'ai trimballé un peu partout avec moi. Je m'en sers sois avec une paire de focal alpha 80 pre-amplifiée, soit avec un ampli casque geshelli archel 2.5 pro + HD650 (excellente combinaison). La télécommande est pratique.
rapport qualité prix fou !!!
Excellent DAC, franchement pour le prix ce DAC est à la hauteur de bien d'autres qui sont à des tarifs bien supérieurs, l'esthétique est de mon point de vue très séduisante. Associé à l'ampli SMSL SA300 et mes Dynaudio Emit M20, c'est que du bonheur, clarté précision, neutralité, j'adore ! Foncez !
This is the MKII version of SMSL Sanskrit 10th anniversary edition : an original and aesthetic device with extremely complete...
