SMSL SU-9n DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512
Little brother of the SMSL SU-9, the SU-9n is a modified version, with all the characteristics of its model, but this time without the support of MQA files, of the Bluetooth UAT codec and with a slightly less powerful USB interface, to reach a lower selling price. The conversion chip remains unchanged, the SU-9n using the excellent ESS ES9038Pro DAC, supporting high resolution files up to PCM 32bit 768kHz and DSD512.
By buying this product you get 39 loyalty points
Reference : 15738
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 27-05-2025.
SMSL SU-9n
Ergonomic, the SU-9n, like its big brother, displays a nice color screen on the front, with a rotary knob to easily navigate through the menus, adjust the volume level, select a source or turn the unit on and off.
The SU-9n is also equipped with a complete connectic. There are Toslink optical, coaxial and USB (XMOS XU208) inputs and single-ended RCA as well as balanced XLR outputs. The SMSL DAC also supports, thanks to a Qualcomm reception chip, Bluetooth 5.0 transmission, so it is possible to broadcast your music remotely, directly from a smartphone.
The internal design of the SU-9n, particularly careful and well thought out, allows it to develop a precise, rich and dynamic sound reproduction.
SU-9n
SU-9
THD+N
0.00006%
0.00008%
MQA
Not supported
Supported
Bluetooth
5.0 (UAT not supported)
5.0 (UAT supported)
Clock
CK-02 clock processing circuit
2x Low phase noise oscillators
XMOS
XU208 8 cores
XU216 16 cores
Bluetooth 5.0
The SMSL SU-9n embeds a Bluetooth 5.0 QCC5125 reception chip from Qualcomm. It is thus possible to stream its music in wireless. Moreover, it supports some codecs of high resolution transmission, such as the aptX, the aptX-HD or the LDAC.
Quality audio components
The SU-9n uses only high quality electronic components, integrated in a neat circuit, and contributing to the excellent sound reproduction of the device. The famous ES9038Pro DAC chip and the XU208 XMOS USB interface are used, as well as an ES9311Q ultra low noise linear voltage regulator, a clock circuit optimized for ultra low jitter and a shielded low noise power supply stage.
1Volume knob
2Screen
3IR Receiver
4Bluetooth antenna
5Optical input
6RCA output
7XLR output
8Coaxial input
9USB input
10Power supply
Technical charateristics
Product typeDAC
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
Outputs1x Single-ended stereo  RCA
1x Balanced stereo XLR
Output level (Pre mode)XLR : 4.8Vrms
RCA : 2.3Vrms
Output level (Fixed mode)XLR : 4.3Vrms
RCA : 2Vrms
THD+N0.000065% (-123.5dB)
0.000055% (-125dB, A-Weighting)
Dynamic rangeXLR : 130dB
RCA : 123dB
SNR130dB
Output impendaceXLR : 207Ω
RCA : 142Ω
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD up to DSD64
Supported Bluetooth codecsLDAC : 24bit 96kHz (990kbps / 660kbps / 330kbps)
aptX-HD : 24bit 48kHz (576kbps)
aptX : 16bit 44.1kHz (352kbps)
SBC : 16bit 44.1kHz (328kbps)
AAC : 16bit 44.1kHz (320kbps)
Supplt voltage100-240V 50/60Hz (Cable included)
Consumption5W
Dimensions187.5 x 154 x 40mm
Weight790g
Housing materialAluminum
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
3 reviews
SMSL SU9n
The SU9n was delivered a few days ago, and everything went well as usual when ordering from Audiophonics. The unit works flawlessly and I can now say after a few days that it plays very clear and transparent. I do not notice any euphonic or flowery tendencies, but a very neutral, detailed reproduction with very good spatiality and precision. This also in Bluetooth mode, which surprises me and makes me very happy. It also offers all the connections I need. My conclusion: Enormously high level at a very fair price. You have to dig much deeper into your pocket elsewhere than for SMSL. Splendid!
This review has been posted for SMSL SU-9n DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512
DAC très performant
Très bon DAC. Utilisé avec un bloc de puissance Audiophonics HPA S400 ET, le couple s'entend à merveille. Le couple surpasse un ampli intégré de renom que j'avais de la même gamme de prix et ça s'entend!
Bon rapport qualité/prix.
SMSLSu9
Ce DAC est une merveille. Détails espace limpide raffiné il est nettement mieux pour moi que le DAC intégré de mon lecteur Luxman D05u. Belle référence
Little brother of the SMSL SU-9, the SU-9n is a modified version, with all the characteristics of its model, but this time without the support of...
