SMSL VMV D2 Balanced DAC AK4499 I2S XMOS Bluetooth aptX-HD LDAC UAT 32bit 768kHz DSD512 MQA
10%
The SMSL VMV D2 is a high-end DAC, embedding high-end components within a neat architecture, for exceptional performances. At the heart of the DAC, the digital to analog conversion stage is based on a AKM AK4499 chip. Furthermore, the D2 is also very versatile, with a full range of connectors and practical functions.
Reduced price!
Reference : 15694
Limited special offer
1 649,00 €tax incl.
-10%
1 484,10 €tax incl.
1 236,75 € tax excl.
SMSL VMV D2
DAC AK4499 I2S XMOS Bluetooth aptX-HD LDAC UAT Balanced 32bit 768kHz DSD512 MQA
SMSL VMV D2 DAC AK4499 I2S XMOS Bluetooth aptX-HD LDAC UAT Symétrique 32bit 768kHz DSD512 MQA
AKM AK4499EQ DAC
The SMSL VMV D2 embeds an AKM AK4499EQ conversion chip to provide excellent performance and a precise, lively and rich sound reproduction. The Velvet Sound architecture of these DACs allows to reach a very low distortion level and a THD+N measured at -123ddB.
The chip is produced using Premium Audio LSI and non-magnetic encapsulation technology. These improve the performance in terms of noise, especially in the low frequencies.
MQA & MQA CD
The D2 benefits from a total support of MQA (Master Quality Authenticated), allowing the device to decode these files in order to reach a sound quality as close as possible to the original recordings. Moreover, the digital output (Optical or Coaxial) of a CD player can be transmitted to the SMSL VMV D2 MQA decoder. The latter will be able to restore the original high resolution signal and confirm it using the MQA signature authentication system.
Bluetooth 5.0
Integrating a Bluetooth 5.0 Qualcomm CSR8675 receiver, the D2 allows you to broadcast your music wirelessly, directly from a connected smartphone. With the support of the codecs of transmission Bluetooth aptX, aptX-HD, LDAC and UAT, it is moreover possible to benefit from a quality of restitution equal or superior to that of the CD.
USB XMOS Interface
The USB-B input of the SMSL VMV D2 is associated to a second generation 16 cores XMOS interface: the XU216. This one ensures the reception and the decoding of audio streams via USB while supporting high resolution files up to PCM 32bit 768kHz and DSD512.
Optimised circuits
All the circuits of the SMSL VMV D2 benefit from a careful and optimized design, using only high quality components dedicated to audio. In addition to the AK4499EQ DAC or the XMOS XU216 USB interface, the DAC is equipped with two Accusilicon ultra-low phase noise clocks or an ultra-low noise power supply stage with an output noise floor of only 1.8µVrms embedding two Noratel toroidal transformers, to independently power the digital and analog circuits.
Adjustable XLR phase
A rare but very useful feature, the SMSL VMV D2 allows you to invert the phase of the balanced XLR output. Thus, the pinout of this output adapts to your system for an optimal compatibility.
1Screen
2IR Receiver
3Input selector
4FN Button
5LED Indicator
6Multifunction knob
7RCA Output
8Optical input
9Bluetooth antenna
10Balanced XLR output
11AES/EBU input
12Coaxial input
13I2S input
14USB input
15External clock input
16Power connector (100-240VAC)
Product typeDAC
DAC ChipAKM AK4499
USB InterfaceXMOS XU216
Bluetooth receiverQualcomm CSR8675
Inputs1x AES/EBU
1x SPDIF Coaxial
1x I2S via HDMI
1x Optical Toslink
1x USB-B
Bluetooth 5.0
1x BNC input for external clock (50Ω)
1x Balanced stereo XLR
Supported sampling ratesUSB, I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Coaxial, Optical, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA CD
Bluetooth : PCM up to 24bit 192kHz (UAT) / 24bit 96kHz (LDAC) / 24bit 48kHz (aptX HD), MQA
Clock frequency10MHz / 11.2896MHz / 12.288MHz / 16.9344MHz
25MHz / 27MHz / 33.8688MHz
THD+N0.000068% (-123dB)
0.000058% (-124dB, A-Weighting)
Dynamic rangeXLR : 131dB
RCA : 125dB
SNR131dB
USB TransmissionAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, LDAC, UAT
Supply voltage1002-240VAC (power cable included)
Consumption< 10W
Standby : < 0.5W
Dimensions280 x 240 x 39mmmm
Weight3kg
Housing materialAluminum
Package1x SMSL VMV D2
1x Power cable
1x Bluetooth antenna
1x Remote control
1x USB Cable
Spikes
InputBNC
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipAK4499
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
3 reviews
VMV d2
Un mot !
FANTASTIQUE.
This review has been posted for SMSL VMV D2 Balanced DAC AK4499 I2S XMOS Bluetooth aptX-HD LDAC UAT 32bit 768kHz DSD512 MQA
Un super rapport qualité/prix
J'ai beaucoup testé de DACs ses derniers temps, notamment quasiment tous ceux à base d'AKM4499, (qui va devenir collector car plus produite par AKM, l'usine ayant brûlé). Et bien ce SMSL VMV D2 est la meilleure implémentation de cette puce que j'ai pu écouter/comparer: Le son est au top, avec un medium très charmeur rappelant les DACS R2R, des basses présentes et puissantes et un registre aiguë fin et délié, même si pas particulièrement mis en avant. Une très belle réussite car ils ont respecté la philosophie du "velvet sound" d'AKM. Ce DAC est peut être le meilleur de la lignée VMV, et pour moi largement supérieur aux DACs à base d'ESS sabre !
MERVEILLEUX
Ce Dac est une incroyable surprise - ce qui n'est pas toujours le cas de mes acquisitions. Mon système (enceintes atlantis labs AT31 + LUXMAN L 509X) a été transfiguré. Pour plus de détails je renvoie a la REVIEW de SOUNDNEWS : vous aurez exactement ce que ce testeur y décrit (au millimètre). J'avoue avoir été sur la réserve à la commande pour le médium et la musicalité mais c'est superbe. C'est plein de matière et de technique. ET LE PLUS IMPORTANT et je ne m'y attendait pas : IL EST EXCEPTIONNEL en préampli et j'attaque directement le bloc du LUXMAN avec un meilleur résultat que le préamplificateur Luxman (Si!). Jusque la tout mes DAC étaient un peu décharnés en branchement direct : perte signal, timbres etc. La c'est le rêve et avec un grave d'un autre niveau pour la rapidité et les impacts. J'envisage d'acheter des blocs de puissances plus conséquents vu la synergie. Quelle transparence, quel niveau de détails et ce fond noir de la scène. Bref conquis.
Enfin le changement de la phase en façade est génial et la qualité en Bluetooth est également bluffante. J'espère qu'il durera dans le temps car vraiment très bon a ce prix. Ce n'est pas un DCS BARTOK mais pour écouter beaucoup de DAC dans ce créneau de prix et au delà c'est très fort. Impossible de se tromper.
The SMSL VMV D2 is a high-end DAC, embedding high-end components within a neat architecture, for exceptional performances. At the heart of the DAC,...
