TOPPING D70 PRO OCTO DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptive 32bit 768kHz DSD512 Black
The D70 Pro OCTO Topping DAC is packed with the refinements of a high-end audio product. With its high-performance chips, ultra-low jitter clocks, latest-generation interfaces and great versatility, this converter offers exceptional audio reproduction, characterized by magnificent transparency and richness of sound, as well as practical, useful features.
Reference : 18141
469,00 €tax incl.
390,83 € tax excl.
Shipping date: 12-05-2026.
DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Black
TOPPING D70 PRO OCTO DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Black
The D70 Pro OCTO Topping DAC is packed with the refinements of a high-end audio product. With its high-performance chips (8x CS43198), ultra-low jitter clocks, latest-generation interfaces and great versatility, this converter offers exceptional audio reproduction, characterized by magnificent transparency and richness of sound, as well as practical, useful features.
8x CS43198 DAC chip
The D70 PRO OCTO features no less than 8 CS43198 DAC chips, enabling it to support PCM audio streams up to 32bit 768kHz and DSD up to DSD512.
Bluetooth 5.1
This DAC supports the best Bluetooth formats such as LDAC, aptx-Adaptive and apt XHD. High-resolution files can therefore be transmitted to it for a superb listening experience, all with the convenience of wireless.
Extraordinary measures
The extraordinary measurements of the OCTO D70 Pro ensure a very rich and detailed level of sound reproduction.
Plug and Play: broad compatibility
The OCTO D70 Pro has a wide system compatibility: Windows 10, Windows 11, Mac OS, Linux, IOS, Android. Simply connect it to your audio source and start playing. The USB plug is based on the XMOS XU316 chip and a custom Thesycon driver, so it's very stable.
A driver and settings are required for the ASIO application on Windows.
Connectivity & Features
With its multitude of functions and connectors, Topping's D70 PRO OCTO can be integrated into the vast majority of audio systems, offering numerous options for use and installation. Input connections include AES/EBU, Coaxial SPDIF, Optical Toslink and USB.
Outputs include balanced XLR and unbalanced RCA. The D70 PRO OCTO lets you select the output so as to send the audio stream to just one of them, or to both at the same time.
In addition, XLR 4V and RCA 2V outputs can be boosted to XLR 5V and RCA 2.5V.
1Color display screen
2Menu screen button
3Volume control
4Balanced stereo XLR output
5Stereo RCA output
6Coaxial input
7Optical Toslink input
8Bluetooth antenna
9USB-B input
10AES/EBU input
1112V Trigger
12IEC socket/Power switch
Integrated preamp function
The D70 PRO OCTO also acts as a preamplifier, since it includes a volume controller. This volume control function can be deactivated, however, so that the D70 PRO OCTO can be used only as a DAC with output levels constantly at their maximums, i.e. 4Vrms for the XLR output and 2Vrms for the RCA output.
12V trigger option
This function enables the D70 PRO OCTO to be controlled or to control other devices so that they can be switched on and off simultaneously.
A new screen with integrated controls
The D70 Pro OCTO comes with a new color screen and 3 control buttons for an even better experience. What's more, this screen can display certain information (FTT and VU) according to your needs.
Remote control
1ON/OFF button
2Volume +
3Previous source
4Volume -
5NC
6Filter selection
7Automatic power on
8Mute mode
9Output mode selection
10Next source
11NC
12NC
13Brightness screen adjustment
Dimensions
Product typeDAC
DAC Chip8x CS43198
USB interfaceXMOS XU316
Input1x Optical Toslink
1x USB-B
1x Coaxial SPDIF
1x AES/EBU
Bluetooth
Supported sampling ratesUSB: PCM Up to 32bit 768kHz / DSD Native Up to DSD512 / DSD DoP Up to DSD256
Coaxial, Optical, AES: PCM Up to 24bit 192kHz
Supported Bluetooth codecsBluetooth : SBC, ACC, LDAC,aptX, aptX HD, aptX Adaptative
Ouput1x XLR balanced
1x RCA unbalanced
THD+NRCA : <0.00008% @ 1kHz A-Weighted
XLR : <0.00007% @ 1kHz A-Weighted
THD @ 90Bw (Not Weighted)RCA : <0.0004% @ 20-20kHz
XLR : <0.0002% @ 20-20kHz
SNRRCA : 128dB @ 1kHz A-Weighted
XLR : 134dB @ 1kHz A-Weighted
Dynamic RangeRCA : 128dB @ 1kHz A-Weighted
XLR : 1334dB @ 1kHz A-Weighted
Fréquency responseRCA : 20Hz - 20kHz (+/-0.5dB) / 20Hz - 40kHz (+/-0.2dB)
XLR : 20Hz - 20kHz (+/-0.2dB) 20Hz - 40kHz (+/-0.2dB)
Output voltageRCA : 2.1Vrms @ 0dBFS (4V Mode) / 2.6Vrms @ 0dBFS (5V Mode )
XLR : 4.2Vrms @ 0dBFS (4V Mode/ 5.2Vrms @ 0dBFS (5V Mode )
Noise RCA : <1.0µVrms
XLR : <1.0µVrms
Channel crosstalkRCA : -124 dB @ 1Khz
XLR : -149 dB @ 1Khz
Channel balanceRCA : 0.3dB
XLR : 0.3dB
Output impedanceRCA : 50 Ohms
XLR : 100 Ohms
Power supply100V-220V AC 50Hz/60Hz via IEC (cable supplied)
Housing materialAluminium
Dimensions22.2 x 17.6 x 4.8cm
Weight1.9kg
Package1x Topping D70 PRO OCTO
1x IR remote control
1x USB cable
1x Power cable
1x Bluetooth Antenna
1x Manual
1x Warranty card
InputAES/EBU
DAC / ADC ChipCS43198
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
8 reviews
So klingt Hifi
Ich habe den DAC wenige Tage, aber aus meiner Erfahrung heraus kann ich sagen, dass dieses Gerät die Musik so wieder gibt, wie sie ist.
Der Charakter ist unverfärbt, nicht künstlich aufgebläht. Das Gesamtbild ist offen und klar und nichts ist überbetont. Ein wirklich sehr zu empfehlendes Gerät.
This review has been posted for TOPPING D70 PRO OCTO DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptive 32bit 768kHz DSD512 Black
Great DAC
Connected the D70 Pro Octo to an A70Pro (preamp) and a LA90D power amp. An all Topping setup. Great sound, very open, transparent and great detailing!
Petit mais costaud !
J'ai pu avoir ce préampli dac d'occasion proche du neuf , et je l'adore pour son écran très informatif , concernant sa sonorité il as un son très penchant vers le médium aigu en mode préampli mais en mode dac il est parfait !
Belle surprise
Après avoir longuement utilisé un Audio GD 19 SINGULARITY qui m'a donné de belles écoutes, ce Topping est un passage pour l'écoute du DSD. DAC très musicale, apporte une belle précision des notes. Passage directement en mode NOS des sa mise en route.
Un DAC fantastique de Topping
J'ai maintenant deux de ces appareils et je suis assez enthousiaste à propos de ce DAC. J'ai déjà testé de nombreux DAC différents, de Sabaj, SMSL, Eversolo, ainsi que d'autres modèles de Topping, le D70 Pro Sabre et le E70 Velvet. Le E70 est génial, le son est dynamique et clair, seul le D70 Pro Octo surpasse le E70V en termes de clarté et de transparence. Le D70 Pro Octo n'est pas le DAC le plus rapide, c'est clairement le D70 Pro Sabre qui a une longueur d'avance, il est vraiment extrêmement rapide et clair comme du cristal, par rapport à l'Octo, le son est quand même un peu plat et manque un peu de profondeur et de chaleur. Le son de l'Octo a un large spectre dynamique, les basses sont profondes et fermes, les médiums et les aigus sont clairs, le son semble "rangé", structuré, pas comme chez beaucoup d'autres où on est complètement dépassé par la transparence. Un super produit de Topping !
The D70 Pro OCTO Topping DAC is packed with the refinements of a high-end audio product. With its...
