This DAC is delivering detail and clarity that is hard to get for unless you are willing to pay for top MSB/dCS or similar priced products. Highly recommend.
By buying this product you get 179 loyalty points
Product updated to firmware V1.46.
The Topping D900 pushes the boundaries of audio fidelity with an exclusive 32-phase DSM (Discrete Sigma Modulation) architecture. A true showcase of Topping's technological know-how, this top-of-the-range DAC combines digital precision, organic musicality and total flexibility to sublimate all your sources. It supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. Its digital-to-analog conversion stage is supported by an Altera Max II CPLD and Accusilicon 45MHz/49MHz clocks. Numerous features are available, such as Bluetooth 5.1 supporting LDAC, and a 10-band parametric equalizer accessible via the “Topping Tune” application. When it comes to connectivity, the D900 is well equipped with digital inputs for a wide range of configurations, while its outputs include two balanced XLR outputs: a line output and a preamp output.
The D900 is based on a 1bit PSRM discrete digital-to-analog conversion module. This circuit preserves the integrity of the signal while the DAC is working, enabling it to offer exceptional performance, with THD+N below -140dB and SNR of 131dB. This Topping DAC also incorporates a new I/V conversion circuit for high dynamics and an immersive sound experience.
On the front of the D900 is a beautiful color screen, powered by Topping's Aurora UI interface, for the ultimate user experience. This interface allows you to display all the information on the current playback, easily navigate through the device's parameters, and display an FFT spectrum or various vumeters. Added to this is a premium-quality, aluminum-bodied remote control.
In terms of connectivity, Topping has chosen to integrate a latest-generation Qualcomm QCC5125 Bluetooth receiver chip. As a result, the D900 supports high-resolution Bluetooth transmission codecs SBC, AAC, aptX, aptX-HD, aptX-Adaptive and LDAC. LDAC 24bit 96kHz, superior to standard CD quality, offers a reliable, stable and pleasant listening experience.
In addition to its many features, the D900 benefits from a new 10-band parametric equalizer for highly precise adjustment of frequencies and gain. This adjustment software offers the possibility of fully personalized rendering by the user.
Topping Tune will be available on MAC OS in the second half of 2025. It is currently only available for Windows.
The D900 now includes a Crossfeed function dedicated to headphone listening, which can be activated via firmware update V1.46 or later. This technology faithfully reproduces HRTF characteristics and room acoustics, eliminating the “in-head” listening effect and feeling of excessive proximity that are common with headphones. Thanks to precise tonal calibration, it combines sound accuracy and realistic spatialization without the distortions of simple frequency correction.
For a more relaxed experience, a simplified BS2B-based mode is also available: it offers sound reproduction similar to that of speakers, without relying on the acoustic reflections of the room. Ideal for listeners seeking an immersive and natural listening experience, this feature enhances the versatility of the D900 and significantly improves the listening experience.
| 1 | Screen |
| 2 | Volume control / multi-function button |
| 3 | XLR preamp output |
| 4 | XLR line output |
| 5 | I2S input via HDMI |
| 6 | AES/EBU input |
| 7 | 2x Toslink optical input |
| 8 | 2x Coaxial input |
| 9 | Bluetooth antenna |
| 10 | USB-B input |
| 11 | USB-C input |
| 12 | In/Out trigger |
| 13 | IEC input / Power switch |
"You get the benefits of the highly sought-after “discrete 1-bit” DAC technology with virtually no compromises. Achieving this level of performance using a large number of individual components is no easy feat and demonstrates exceptional technical expertise. Its price is high compared to solutions based on integrated circuits. But it’s a “bargain” compared to high-end DACs with similar architecture, which generally offer inferior performance. I recommend the Topping D900. If you’re looking for a custom-built DAC, this is the one for you."
| Specifications | |
| Product type | DAC |
| DAC chip | PSRM circuit |
| Bluetooth chip | QCC5125 |
| CPLD | Altera Max II |
| Inputs | 1x USB-C 1x USB-B 2x Coaxial 2x Toslink optical 1x AES/EBU 1x I2S via HDMI Bluetooth |
| Outputs | 1x XLR line output 1x XLR preamp output |
| Supported sample rates | PCM up to 32Bit 768kHz DSD up to DSD512 |
| Bluetooth version | 5.1 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX-HD, aptX-Adaptive and LDAC |
| In/Out trigger | |
| DAC + Preamplifier function | |
| 10-band equalization | |
| Color display | |
| Interface | Aurora UI |
| XLR line output specifications | |
| THD+N @ A-WT | < 0.000055% @ 1kHz |
| THD @ No-wt 45kBw | < 0.00015% @ 20-20kHz |
| SNR @ A-WT | 131dB @ 1kHz |
| Dynamic range @ A-WT | 131dB @ 1kHz |
| Frequency response | 20Hz-20kHz (+/-0.3dB) 20Hz-40kHz (+/-1.0dB) |
| Output level | 4.2Vrms @ 0dBFS (4V mode) 5.2Vrms @ 0dBFS (5V mode) |
| Noise @ A-WT | < 1.5uVrms |
| Channel crosstalk | -147dB @ 1kHz |
| Channel balance | 0.3dB |
| Output impedance | 100 ohms |
| XLR preamp output specifications | |
| Frequency response | 20Hz-20kHz (+/-0.3dB) 20Hz-40kHz (+/-0.1dB) |
| Output level | 10.5Vrms @ 0dBFS (4V mode) 13Vrms @ 0dBFS (5V mode) |
| Noise @ A-WT | < 1.6Vrms |
| Output impedance | 100 ohm |
| General | |
| Color | Silver |
| Package | 1x Topping D900 1x Bluetooth remote control 1x Bluetooth antenna 1x Power cord |
| Input | USB |
| Input | Optical |
| Input | I2S via HDMI |
| Input | SPDIF |
| Input | Bluetooth |
| Input | AES/EBU |
| Output | XLR |
| DAC / ADC Chip | PSRM |
| Color | Silver |
| Networking | No |
| Remote Control | Yes |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bjarke B.
