By buying this product you get 22 loyalty points
Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM 768kHz and DSD512. The DRV108 also benefits from Bluetooth 5.1 bi-directional connectivity, allowing you to enjoy the convenience of a wireless connection, whatever your system configuration.
The DRV108 offers a wide range of connectivity options. It features XLR and RCA outputs on the analog side, as well as Toslink optical and coaxial on the digital side. But that's not all: this CD player also features a 3.5mm headphone output on the front panel, amplified by a TPA152 chip. On the digital input side, two USB-A ports are available, one for a USB drive, the other for a signal from an external device. Finally, the DRV108 is also equipped with Bluetooth 5.1 bi-directional connectivity for wireless use.
To deliver the highest-quality digital-to-analog conversion possible, the DRV108 relies on an ES9038Q2M chip, handling signals up to PCM 32bit 768kHz and DSD512, and offering oversampling from CD 44.1kHz to 384kHz. The choice of ESS's DAC chip also ensures crystal-clear sound reproduction, devoid of any parasitic noise or distortion. Indeed, the DRV108 boasts a dynamic range of 133dB, an impressive signal-to-noise ratio of 129dB and distortion of -120dB.
| Specifications | |
| Product type | CD Player DAC |
| Processor | TMC688 |
| Inputs | CD Player 1x USB-A (USB Disk up to 32Go) 1x USB-A (USB-DAC) Bluetooth |
| Outputs | 1x Optical Toslink 1x Coaxial 1x Single-ended stereo RCA 1x Balanced stereo XLR 1x Jack 3.5mm headphone output Bluetooth |
| Bluetooth version | Bluetooth 5.1 bidirectional |
| Supported formats | WAV / FLAC / APE / MP3 / WMA |
| Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 |
| Total harmonic distortion (THD) | 0.05% |
| Signal-to-noise ratio (SNR) | > 90dB |
| Headphone output power | 2x50mW @ 32Ω |
| Output level | XLR: 3.5V RCA: 1.5V |
| General | |
| Power supply | 50Hz 220V AC |
| Consumption | 40W |
| Dimensions | 360 x 147 x 210mm |
| Weight | 4.1kg |
| Color | Silver |
| Package | 1x Thinkya DRV108 1x Infrared remote control 1x Bluetooth antenna |
| Input | Bluetooth |
| Input | USB |
| Input | CD |
| Output | RCA |
| Output | XLR |
| Output | Bluetooth |
| Output | Optical Toslink |
| Output | Jack 3.5mm |
| Output | Coaxial SPDIF |
| DAC / ADC Chip | ES9038Q2M |
| Color | Silver |
| Networking | No |
| Remote Control | Yes |
Average votes 4.5 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pavel C.
Andrew H.
Jean-Charles B.
