TOPPING DX1 DAC Headphone Amplifier AK4493S XMOS XU208 32bit 384kHz DSD256 Silver
Topping unveils with the DX1 a compact, affordable and yet powerful DAC and headphone amplifier combo. It benefits from an optimized design allowing an efficient digital/analog conversion as well as a robust headphone amplification.
Reference : 16838
99,00 €tax incl.
82,50 € tax excl.
Last items in stock !
Shipping date: 28-05-2026.
Topping DX1
Topping DX1 DAC Amplificateur Casque AK4493S XMOS XU208 32bit 384kHz DSD256
AK4493S DAC & XMOS XU208 USB Interface
The DX1 features the brand new AKM AK4493S DAC chip. This ensures a precise and musical conversion, while allowing, in association with the USB XMOS XU208 interface, the support of high resolution audio streams, up to PCM 32bit 384kHz and DSD256.
Discrete LNRD
The Topping DX1 uses a discrete LNRD (Low Noise Reference Driver) circuit to effectively filter out noise and interference from the USB power supply. As a result, the power supply stage is able to provide the DX1's audio circuitry with a clean and stable electrical signal.
The volume of the line output is fixed at its maximum level and is not adjustable.
The headphone outputs and the line output are active simultaneously.
Product typeDAC and headphone amplifier
DAC chipAKM AK4493S
Input1x USB-B
Outputs1x Stereo RCA line out (fixed volume)
1x Jack 3.5mm headphone output
1x Jack 6.35mm headphone output
Native DSD up to DSD256
DSD DoP up to DSD128
DAC Parameters (USB Input @ 44.1kHz)
THD+N @ 1kHz, A-Weighted< 0.0002%
THD @ 20Hz-20kHz, 90kBw< 0.0006%
SNR @ 1kHz, A-Weighted120dB
Dynamic range @ 1kHz, A-Weighted120dB
Frequency repsonse20Hz - 20kHz (±0.3dB)
20Hz - 40kHz (±0.7dB)
Output level2.0Vrms @ 0dBFS
Crosstalk @ 1kHz-112dB
Channel balance0.3dB
Output impedance22Ω
Headphone amplifier parameters
THD+N @ 1kHz, A-Weighted< 0.0003% @ 200mW, 32Ω
< 0.0002% @ 45mW, 300Ω
THD @ 20Hz-20kHz, 90kBw< 0.003% @ 200mW, 32Ω
< 0.001% @ 45mW, 300Ω
SNR @ Max Out, 1kHz, A-Weighted118dB
Dynamic range @ 1kHz, A-Weighted118dB
Frequency response20Hz - 20kHz (±0.3dB)
Output level2.2Vpp @ G=L
11Vpp @ G=H
Noise @ A-Weighted< 1.0µVrms
Crosstalk @ 1kHz-86dB
Gain-2dB (Vrms/FS) @ G=L
12dB (Vrms/FS) @ G=H
Output impedance< 0.7Ω
Output power2x 280mW @ 32Ω, THD+N <0.1%
2x 190mW @ 64Ω, THD+N <0.1%
2x 51mW @ 300Ω, THD+N <0.1%
Load impedance> 8Ω
Dimensions100 x 98 x 32mm
ColorSilver
Package1x Topping DX1
1x USB-B cable
OutputJack 6.35mm
OutputJack 3.5mm
DAC / ADC ChipAK4493S
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Topping unveils with the DX1 a compact, affordable and yet powerful DAC and headphone amplifier combo. It benefits from an optimized design...
