TOPPING DX5 II DAC Headphone Amplifier Black
With the DX5 II, Topping presents the direct heir to its famous DX5 DAC and headphone amplifier. This new version features a host of changes, improving on its predecessor in absolutely every respect. The digital/analog conversion stage is now entrusted to two ES9039Q2M chips in a symmetrical architecture, for support of sampling rates up to PCM 32bit 768kHz and DSD512. As for amplification, the brand's classic NFCA architecture has been drastically evolved to offer four-channel 2x7600mW amplification under 16Ω in a brand-new design called X-Hybrid.
Reference : 20820
299,00 €tax incl.
249,17 € tax excl.
Topping DX5 II DAC 2xES9039Q2M Headphone Amplifier X-Hybrid Bluetooth 32bit 768kHz DSD512 Black
Topping DX5 II: Front view
Topping DX5 II: ES9039Q2M dual DAC for unrivalled sound quality
The Topping DX5 II uses two ES9039Q2M DAC chips in a symmetrical architecture, offering outstanding digital-to-analog conversion. It boasts a distortion rate of 0.00006% for an impressive signal-to-noise ratio and dynamic range of 133dB. What's more, the inclusion of an XMOS XU316 USB interface makes the most of the DAC chips used, ensuring signal conversion at sampling rates up to PCM 32bit 768kHz and DSD512.
Topping DX5 II: ES9039Q2M DAC chips
Topping DX5 II: X-Hybrid amplifier circuit
Topping DX5 II: Revolutionary X-Hybrid amplification circuitry
For its amplification stage, the Topping DX5 II evolves the brand's characteristic NFCA architecture into X-Hybrid technology. This is a three-stage amplification architecture characterized by record efficiency, reducing power consumption while minimizing heat generation. Despite its small chassis, the DX5 II houses four-channel symmetrical amplification.
Topping DX5 II: Extended compatibility with all headphone outputs
To ensure compatibility with all headphones and earphones on the market, the Topping DX5 II makes no concessions, featuring single-ended 6.35mm jack, balanced 4.4mm jack and balanced 4-pin XLR headphone outputs. What's more, its 2x7600mW of power coupled with a low noise level of just 1.8µV ensures that even the most power-hungry headphones can be driven with ease, and without the slightest trace of background noise.
Topping DX5 II: when used with headphones and earphones
Topping DX5 II: Revolutionary Aurora UI user interface
With the new DX5 version, Topping has also taken the opportunity to revamp its user interface, introducing the Aurora UI. This new, highly customizable interface allows you to modify its colors at will for optimum readability, and integrates a VU meter and FFT (Fast Fourier Transform) display in addition to the classic playback information, offering a rich visual experience.
Topping DX5 II: Sample screens with Aurora UI
Topping DX5 II: Customizable 10-band equalization
To give you maximum control over sound reproduction, Topping has developed a 10-band equalizer for the Topping DX5 II. Once you've defined your target curve using the dedicated software/application, simply import it into your device to enjoy it. It's worth noting that you can save several different sound profiles and switch between them at will, allowing you to adapt sound reproduction to your headphones on the fly.
This software/application is currently being tested by the Topping teams. It will be available and made compatible with the DX5 II shortly via a firmware update. The mobile application is scheduled for release first on Android, then on iOS.
Topping Tune will be available on MAC OS in the second half of 2025. It is currently only available for Windows.
Topping DX5 II: Topping EQ
Topping DX5 II: Bluetooth connectivity
Topping DX5 II: Advanced Bluetooth connectivity
For maximum ease of use, the Topping DX5 II is also equipped with Bluetooth 5.1 connectivity. This supports sampling rates up to PCM 24bit 96kHz via the high-quality protocols LDAC, aptX Adaptive, aptX, aptX HD, AAC and SBC, ensuring high-quality wireless transmission.
Topping DX5 II: Preamplifier mode and intelligent volume control
Always in the spirit of flexibility of use and comfort, the Topping DX5 II also features a “Preamp” mode, enabling it to be directly connected to a power amplifier or active speakers to control volume. What's more, the Topping DX5 II features an automatic volume save function, allowing it to automatically adjust itself according to your last use when you select another output mode, for a simplified user experience.
Topping DX5 II: used as a preamplifier
Topping DX5 II: 12V trigger input and output
Topping DX5 II: 12V trigger for perfect system integration
Last but not least, the Topping DX5 II also features a 12V trigger input and output, enabling it to synchronize its power-up with the rest of your HiFi installation, for seamless integration of all your devices.
Topping DX5 II overview
Topping DX5 II: rear panel diagram
1Balanced XLR output
2Bluetooth antenna
3Coaxial input
412V trigger input / output
5Single-ended RCA output
6USB-B input
7Optical Toslink input
8IEC power input
9Power switch
Topping DX5 II test by Audio Science Review
No matter how many times Topping produces exceptional audio products, testing their new offerings always puts a smile on my face. They are constantly competing with themselves, upping the performance in every category possible. They now bring extra features in the form of DSP and delightful look and feel. Measured performance is essentially without fault.
It is my pleasure to recommend the Topping DX5 II DAC and Headphone Amplifier.
Product typeDAC
Headphone amplifier
Inputs1x Coaxial
1x USB-B
1x Optical Toslink
Bluetooth
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
1x Balanced Jack 4.4mm headphone output
1x Single-ended Jack 6.35mm headphone output
1x Balanced XLR 4 pins headphone output
DAC chips2x ES9039Q2M
Supported sampling ratesPCM up to 32 bit 768kHz
DSD up to DSD512
Headphone amplification circuitX-Hybrid
Bluetooth chipQCC5125
Supported Bluetooth codecsLDAC, aptX Adaptive, aptX, aptX HD, AAC, SBC
USB interfaceXMOS XU316
DAC specifications (Line out / USB input @ 96kHz)
THD+N @ 1kHz (A-wt)RCA: < 0.00008%
XLR: < 0.00006%
THD @ 20Hz-20kHz 90kBwRCA: < 0.0005%
XLR: < 0.00015%
SNR @ 1kHz (A-wt)RCA: 128dB
XLR: 132dB
Dynamic range @ 1kHz (A-wt)RCA: 128dB
XLR: 132dB
Frequency responseRCA: 20Hz-20kHz (±0.3dB) / 20Hz-40kHz (±1.0dB)
XLR: 20Hz-20kHz (±0.3dB) / 20Hz-40kHz (±1.0dB)
Output levelRCA: 2.5Vrms @ 0dBFS
XLR: 5.0Vrms @ 0dBFS
Noise @ A-wtRCA: < 1.1µVrms
XLR: < 1.3µVrms
CrosstalkRCA: -135dB @ 1kHz
XLR: -147dB @ 1kHz
Channel balanceRCA: 0.3dB
XLR: 0.3dB
Output impedanceRCA: 50Ω
XLR: 100Ω
Headphone amplifier specifications (USB input @ 96kHz)
THD+N @ 1kHz (A-wt)Jack 6.35mm: < 0.00008% @ 200mW, 32Ω / < 0.00007% @ 22mW, 300Ω
Jack 4.4mm, XLR 4 pins: < 0.00008% @ 850mW, 32Ω / < 0.00007% @ 90mW, 300Ω
THD @ 20Hz-20kHz (45kBw)Jack 6.35mm: < 0.0006% @ 200mW, 32Ω / < 0.0005% @ 22mW, 300Ω
Jack 4.4mm, XLR 4 pins: < 0.0005% @ 850mW, 32Ω / < 0.0005% @ 90mW, 300Ω
SNR @ Max Out, 1kHz (A-wt)Jack 6.35mm: 131dB @ 1kHz
Jack 4.4mm, XLR 4 pins: 133dB @ 1kHz
Dynamic range @ 1kHz (A-wt)Jack 6.35mm: 131dB @ 1kHz
Frequency responseJack 6.35mm: 20Hz-20kHz (±0.3dB) / 20Hz-40kHz (±1.0dB)
Jack 4.4mm, XLR 4 pins: 20Hz-20kHz (±0.3dB) / 20Hz-40kHz (±1.0dB)
Output levelJack 6.35mm: 7.2Vpp @ G=L / 24.2Vpp @ G=H
Jack 4.4mm, XLR 4 pins: 15.0Vpp @ G=L / 48.0Vpp @ G=H
Noise (A-wt)Jack 6.35mm: < 1.1µVrms @ G=L / < 2.5µVrms @ G=H
Jack 4.4mm, XLR 4 pins: < 1.6µVrms à G=L / < 4.3µVrms @ G=H
CrosstalkJack 6.35mm: -127dB @ 1kHz
Jack 4.4mm, XLR 4 pins: -143dB @ 1kHz
GainJack 6.35mm: G=L 8.6dB(Vrms/FS) / G=H 18.7dB(Vrms/FS)
Jack 4.4mm, XLR 4 pins: G=L 14.6dB(Vrms/FS) / G=H 24.7dB(Vrms/FS)
Channel balanceJack 6.35mm: < 0.1Ω
Jack 4.4mm, XLR 4 pins: < 0.1Ω
PuissanceJack 6.35mm: 2x 3300mW @ 16Ω THD+N < 1% / 2x 2200mW @ 32Ω THD+N < 1% / 2x 1160mW @ 64Ω THD+N < 1% / 2x 250mW @ 300Ω THD+N < 1% / 2x 120mW @ 600Ω THD+N < 1%
Jack 4.4mm, XLR 4 pins: 2x 7600mW @ 16Ω THD+N < 1% / 2x 6400mW @ 32Ω THD+N < 1% / 2x 4300mW @ 64Ω THD+N < 1% / 2x 990mW @ 300Ω THD+N < 1% / 2x 490mW @ 600Ω THD+N < 1%
PuissanceJack 6.35mm: > 8Ω
Jack 4.4mm, XLR 4 pins: > 8Ω
Package1x Topping DX5 II
1x USB cable
1x Jack 3.5mm to Jack 6.35mm adapter
1x Bluetooth antenna
1x Power cable
1x Remote
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
TOPPING DX5 II DAC 2xES9039Q2M Headphone Amplifier X-Hybrid Bluetooth 32bit 768kHz DSD512 Black
With the DX5 II, Topping presents the direct heir to its famous DX5 DAC and headphone amplifier. This new version features a host of changes,...
