TOPPING DX9 DISCRETE Balanced Discrete R2R DAC Headphone Amplifier NFCA Black
The Topping DX9 DISCRETE is an R2R DAC/headphone amplifier with even better performance than its predecessor, the DX9, which was based on AKM technology. the DX9 DISCRETE is based on a balanced PSRM circuit with 16 elements per channel combined with R2R resistor networks, as well as an AK4118 optical receiver chip and an XMOS XU-316 USB interface, enabling it to support high-resolution sampling rates up to PCM 32-bit 768kHz and DSD512.
By buying this product you get 129 loyalty points
Reference : 21212
1 299,00 €tax incl.
1 082,50 € tax excl.
Shipping date: 07-05-2026.
Topping DX9 Discrete Balanced Discrete R2R DAC Headphone Amplifier NFCA Bluetooth 5.1 32bit 768kHz DSD512 Black
Photo of the TOPPING DX9 DISCRETE
The Topping DX9 Discrete is an R2R DAC / headphone amplifier with even better performance than its predecessor, the DX9, which was based on AKM technology. the DX9 Discrete is based on a balanced PSRM circuit with 16 elements per channel combined with R2R resistor networks, as well as an AK4118 optical receiver chip and an XMOS XU-316 USB interface, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. The circuit is complemented by Altera MAX II CPLD, a high-precision clock, relay volume control, and a 6-channel NFCA amplification circuit for unmatched performance and power.
The DX9 Discrete delivers up to 2x 7080mW into a 32 ohms load via its headphone outputs. Added to this is a QCC5125 Bluetooth receiver chip supporting aptX, aptX Adaptive, aptX HD, and LDAC codecs. In terms of aesthetics, it retains the appearance of its predecessor with a curved case with a transparent top plate and dual color screens featuring the Aurora UI interface. In terms of connectivity, it is not to be outdone with a full range of digital inputs, a set of RCA/XLR line outputs, and a set of RCA/XLR preamplified outputs.
Topping DX9 Discrete: PSMR + R2R hybrid DAC
The Topping DX9 Discrete DAC features the brand's proprietary 1-bit PSRM technology combined with R2R resistor networks for high-precision decoding. Topping's PSRM technology allows the R2R to process a 1-bit signal for even greater stability, less noise, and very high dynamics. This hybrid R2R + 1-bit modulation technology enables the DX9 Discrete to offer an SNR of 131dB.
The DAC architecture of the TOPPING DX9 DISCRETE
Topping DX9 Discrete: Audiophile components
The entire structure of the DX9 Discrete is made up of high-quality, audiophile components. It features a USB-XMOS XU316 interface and an AK4118 optical interface coupled with an Altera MAX II CPLD, enabling it to support high-resolution sampling rates up to PCM 32bit 768 kHz and DSD512 while eliminating jitter to achieve a rate of -160dB.
The components of the TOPPING DX9 DISCRETE
The volume control on the TOPPING DX9 DISCRETE
Topping DX9 Discrete: Volume control via relay system
Within the DX9 Discrete, volume is managed in balanced way using relay and resistor networks for high-precision rendering. Combined with digital volume control, this achieves lower distortion levels and greater noise immunity, preserving sound reproduction for clear, purer rendering.
Topping DX9 Discrete: A high-performance headphone amplifier
The headphone amplification is based on a balanced NFCA circuit and benefits from crossfeed functionality. The amplification circuit to the unbalanced connector and the circuit to the balanced connector are completely independent in order to preserve the signal from any distortion and to be able to deliver high power. The balanced headphone output is capable of delivering up to 2x7080mW under a 32 ohm load (THD+N < 1%). In addition, the crossfeed function simulates the HRTF function for improved spatialization, with greater depth and less channel separation.
The amplification circuit of the TOPPING DX9 DISCRETE
Bluetooth functionality of the TOPPING DX9 DISCRETE
Topping DX9 Discrete: Bluetooth aptX LDAC
The DX9 Discrete features Bluetooth 5.1 functionality thanks to a Qualcomm QCC5125 chip, enabling it to support SBC, AAC, aptX, aptX HD, aptX Adaptive, and LDAC codecs for reliable and stable wireless transmission.
Topping DX9 Discrete: 10-band EQ
To give you complete control over the tone of the sound reproduction, Topping has developed its own 10-band PEQ (parametric equalizer), allowing you to set the frequency response, gain, and bandwidth using the Topping Tune Windows application. The software supports the import of target curves and original curves, as well as curve compensation using target curves. You can also save multiple profiles and switch between them easily.
EQ of the TOPPING DX9 DISCRETE
Topping DX9 Discrete: Refined aesthetics and ergonomics
The rounded curves of the DX9 Discrete give it a unique aesthetic. Combined with two color screens and its Aurora UI interface, the user experience is exceptional. To top it all off, a transparent plate on the top of the device allows you to see its internal circuitry.
The aesthetics of the TOPPING DX9 DISCRETE
Topping DX9 Discrete overview
Overview of the TOPPING DX9 DISCRETE
1Power button
2Dual display
3Multifunction button
4Single-ended 6.35mm jack headphone output
5Balanced 4.4mm jack headphone output
6Balanced 4-pin XLR headphone output
7Balanced XLR stereo pre-out
8Single-ended RCA stereo pre-out
9Single-ended RCA stereo line output
10Balanced XLR stereo line output
11I2S input via HDMI
122x Toslink optical inputs
132x Coaxial inputs
14Bluetooth antenna
15USB-B input
16AES/EBU input
17Trigger 12V
18IEC power supply / Fuse / Power switch
Product typeDAC
Headphone amplifier
Inputs1x USB-B
2x Coaxial
2x Toslink optical
1x AES/EBU
1x I2S via HDMI
Bluetooth
Outputs1x Balanced XLR stereo line output
1x Single-ended RCA stereo line output
1x Balanced XLR stereo pre-out
1x Single-ended RCA stereo pre-out
1x Single-ended 6.35mm headphone jack output
1x Balanced 4.4mm headphone jack output
1x Balanced 4-pin XLR headphone output
DAC1-bit PSRM circuit + R2R
Optical interfaceAK4118
USB interfaceXMOS XU316
Supported sample ratesPCM jusqu'à 32bit 768kHz
DSD jusqu'à DSD512
Bluetooth compatible codecsSBC, AAC, aptX, aptX HD, aptX Adaptive, LDAC
12V trigger
DX9 Discrete DAC (Line Output / USB Source @ 96kHz)
THD+N @ 1kHz (A-wt)RCA : < 0.00007%
XLR : < 0.00006%
THD @ 20-20kHz 90kBwRCA : < 0.0004%
XLR : < 0.0003%
SNR @ 1kHz (A-wt)RCA : 128dB
XLR : 131dB
Dynamic rangeRCA : 128dB
XLR : 131dB
Frequency responseRCA : 20HZ-20kHz (+/-0.6dB) 20Hz-40kHz (+/-2.0dB)
XLR : 20HZ-20kHz (+/-0.6dB) 20Hz-40kHz (+/-2.0dB)
Output levelRCA : 2.5Vrms @ 0dBFS
XLR : 5.2Vrms @ 0dBFS
Noise (A-wt)RCA : < 1.1uVrms
XLR : < 1.6uVrms
Channel crosstalkRCA : -125dB @ 1kHz
XLR : -136dB @ 1kHz
Channel balanceRCA : 0.3dB
XLR : 0.3dB
Output impedanceRCA : 0.3dB
XLR : 0.3dB
Supported sample ratesRCA : 50 ohms
XLR : 100 ohms
DX9 Preamplifier (USB Source @96kHz)
XLR : < 0.00007%
THD @ 20-20kHz 45kBwRCA : < 0.0004%
XLR : < 0.0003%
SNR @ Max out 1kHz (A-wt)RCA : 130dB @ 1kHz
XLR : 131dB @ 1kHz
Dynamic rangeRCA : 130dB @ 1kHz
XLR : 131dB @ 1kHz
Frequency responseRCA : 20Hz-20kHz (+/-0.6dB) / 20Hz-40kHz (+/-2.0dB)
XLR : 20Hz-20kHz (+/-0.6dB) / 20Hz-40kHz (+/-2.0dB)
Output levelRCA : 15Vpp @ G=L / 24Vpp @ G=H
XLR : 15Vpp @ G=L / 48Vpp @ G=H
Measured noise level AP (A-weighted)RCA : < 1.7uVrms @ G=L < 2.0uVrms @ G=H
XLR : < 0.8uVrms @ G=L < 2.1uVrms @ G=H
Effective noise level (A-weighted)RCA : < 1.1uVrms @ G=L < 1.4uVrms @ G=H
XLR : < 0.5uVrms @ G=L < 2.1uVrms @ G=H
Channel crosstalkRCA : -113dB @ 1Khz
XLR : -135dB @ 1kHz
GainRCA : G=L 14.4dB(Vrms/FS) / G=H 20.1dB (Vrms/FS)
XLR : G=L 14.4dB(Vrms/FS) / G=H 26.5dB (Vrms/FS)
XLR : 0.3dB
Output impedanceRCA : 50 ohms
XLR : 100 ohms
DX9 headphone amplifier (USB source @ 96kHz)
THD+N @ 1kHz (A-wt)Single-ended output: < 0.00007% @ output=550mW(32ohms) / < 0.00007% @ output=60mW(300ohms)
Balanced output: < 0.00007% @ output=550mW(32ohms) / < 0.00007% @ output=60mW(300ohms)
THD @ 20-20kHz 45kBwSingle-ended output: < 0.00050% @ output=550mW(32ohms) / < 0.00050% @ output=60mW(300ohms)
Balanced output: < 0.00050% @ output=550mW(32ohms) / < 0.00030% @ output=60mW(300ohms)
SNR @ Max out 1kHz (A-wt)Single-ended output: 130dB @ 1kHz
Balanced output: 131dB @ 1kHz
Dynamic rangeSingle-ended output: 130dB @ 1kHz
Frequency responseSingle-ended output: 20Hz-20kHz (+/-0.6dB) / 20Hz-40kHz (+/-2.0dB)
Balanced output: 20Hz-20kHz (+/-0.6dB) / 20Hz-40kHz (+/-2.0dB)
Output levelSingle-ended output: 15Vpp @ G=L / 24Vpp @ G=H
Balanced output: 15Vpp @ G=L / 48Vpp @ G=H
Measured noise level AP (A-weighted)Single-ended output: < 1.3uVrms @ G=L < 1.6uVrms @ G=H
Balanced output: < 0.8uVrms @ G=L < 2.4uVrms @ G=H
Effective noise level (A-weighted)Single-ended output: < 1.1uVrms @ G=L < 1.4uVrms @ G=H
Balanced output: < 0.5uVrms @ G=L < 2.1uVrms @ G=H
Channel crosstalkSingle-ended output: -130dB @ 1Khz
Balanced output: -133dB @ 1kHz
GainSingle-ended output: G=L 12.5dB(Vrms/FS) / G=H 18.5dB (Vrms/FS)
Balanced output: G=L 12.5dB(Vrms/FS) / G=H 24.5dB (Vrms/FS)
Channel balanceSingle-ended output: 0.3dB
Balanced output: 0.3dB
Output impedanceSingle-ended output: < 0.1 ohms
Balanced output: < 0.1 ohms
Output powerUnbalanced output:
3300mW x2 @ 16 ohms THD+N<1%
2120mW x2 @ 32 ohms THD+N<1%
1190mW x2 @ 64 ohms THD+N<1%
270mW x2 @ 300 ohms THD+N<1%
Balanced output:
10000mW x2 @ 16 ohms THD+N<1%
7080mW x2 @ 32 ohms THD+N<1%
4250mW x2 @ 64 ohms THD+N<1%
1060mW x2 @ 300 ohms THD+N<1%
540mW x2 @ 600 ohms THD+N<1%
Load impedanceSingle-ended output: > 8 ohms
Balanced output: > 8 ohms
Power supply100-240VAC 50-60Hz
Dimensions34x23x6cm
Weight2.75kg
Package1x Topping DX9 Discrete
1x Remote control
1x USB cable
1x Bluetooth antenna
1x 3.5mm to 6.35mm jack adapter
1x AC power cable
TOPPING DX9 DISCRETE measurements
InputI2S via HDMI
InputAES/EBU
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipPSRM
DAC / ADC ChipR2R LADDER DAC
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
2 reviews
Musicaité et présentation d’exception
J’ai fait écouter mon Topping DX 9 Discrete à un ami mélomane et dès que je lui ai fait écouter le morceau « Solo de batterie de Juan del Incina «  il s’est précipité pour le commander chez Audiophonics !
Le morceau de percussion était explosif à cause de la combinaison réussie d’une rapidité fulgurante et d’une dynamique exceptionnelle .
Cet évènement permet d’illustrer mon opinion sur ce DAC très musical.
Je pense qu’il faut l’écouter avant toute décision d’achat .
Philippe Tremblais
This review has been posted for TOPPING DX9 DISCRETE Balanced Discrete R2R DAC Headphone Amplifier NFCA Bluetooth 5.1 32bit 768kHz DSD512 Black
Du Haut de Game abordable
J'ai reçu ce matin le Dac TOPPING DX9 Discrete et j' avoue avoir été doublement surpris par ce produit .
La présentation est extrêmement soignée et en plus la musicalité est vraiment au rendez-vous .
Rien ne manque : espace sonore , incarnation des voix , respect des timbres , bande passante , présence de micro informations et surtout pas de compression de la dynamique .
En un mot ce Dac est proche de la perfection et le rapport qualité prix est excellent même si le produit peu semblait coûteux .
Je le recommande chaudement sans aucune restriction pour tous les audiophiles perfectionnistes .
Un grand merci à David Aubert pour tous ses conseils et pour ses pertinentes remarques .
Philippe Tremblais
The Topping DX9 DISCRETE is an R2R DAC/headphone amplifier with even better performance than its predecessor, the DX9, which was based on AKM...
