beaucoup de détails mais malheureusement la scène sonore est étriqué.tous les instruments sont consentrés sur un même point,le centre des enceintes.dommage.
DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Black
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed based on an ESS ES9068AS digital/analog conversion chip as well as an XMOS XU216 USB interface, allowing it to read high resolution files but also to decode MQA files. It also benefits from a balanced output on TRS connectors.
The E50's digital-to-analog conversion stage uses the latest ESS ES9068AS DAC chip to deliver a transparent and richly detailed sound. The device ensures excellent performance with a very low distortion of 0.00009% or a dynamic range of 126dB.
The USB interface of the Topping E50 uses a second generation XMOS XU216 16-core chip with custom Thesycon driver. Associated with the ES9068AS DAC, this combination allows a perfect sound neutrality but also the support of high resolution files, up to PCM 32bit 768kHz, DSD512 and MQA. The USB input also uses a CPLD to process the clock signal and thus considerably reduce the jitter level.
Topping's DAC benefits from a complete connectivity to adapt to all types of audio systems. We can find USB-B, Optical Toslink and Coaxial as inputs. On the output side, the E50 offers both single-ended RCA and a double 6.35mm TRS jack for balanced output.
The TRS output does not support an adapter to convert the signal to single-ended and cannot be connected directly to headphones.
The Topping E50 is powered by 5VDC, either via its DC jack connector or directly on its USB-B input. It also benefits from an automatic on/off function. Thus, if the E50 receives a signal, it turns on automatically. In the same way, if it does not receive any signal on the selected input during 1 minute, then the E50 turns off.
The E50 has a preamplifier function. It is thus possible to control the volume level thanks to the remote control supplied. Ideal for association with a power amplifier or active speakers.
Product type | DAC |
DAC Chip | ESS ES9068AS |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA |
Entrées | 1x USB-B 1x Optical Toslink 1x Coaxial |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo Jack 6.35mm TRS |
Measurements @ USB, 96kHz | |
THD+N @ A-Weighting | Single-ended: < 0.0001% @ 1kHz Balanced : < 0.00009% @ 1kHz |
THD @ No-Weighting 90kBw | Single-ended: < 0.0003% @ 20Hz-20kHz Balanced : < 0.0003% @ 20Hz-20kHz |
SNR @ A-Weighting | Single-ended : 124dB @ 1kHz Balanced : 126dB @ 1kHz |
Dynamic range @ A-Weighting | Single-ended : 124dB @ 1kHz Balanced : 126dB @ 1kHz |
Frequency response | Single-ended : 20Hz-40kHz (±0.3dB) Balanced : 20Hz-40kHz (±0.3dB) |
Output level | Single-ended : 2Vrms @ 0dBFS Balanced : 4Vrms @ 0dBFS |
Noise @ A-Weighting | Single-ended : < 1.3µVrms Balanced : < 2.3µVrms |
Crosstalk | Single-ended : -130dB @ 1kHz Balanced : -139dB @ 1kHz |
Output impedance | Single-ended : 20Ω Balanced : 100Ω |
Supply voltage | 5VDC |
Dimensions | 129 x 155 x 41mm |
Color | Black |
Package | 1x Topping E50 1x Remote control 1x USB-A to Jack DC power cable 1x USB-A to USB-B cable |
Input | SPDIF |
Input | USB |
Input | Optical |
Output | Jack 6.35mm |
Output | RCA |
DAC / ADC Chip | ES9068AS |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Networking | No |
Remote Control | Yes |
Average votes 4.3 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Didier f.
Bertrand D.
Bruno M.
didier g.
Robert L.
