TOPPING E70 VELVET DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Silver
With the E70 Velvet, Topping offers a new version of the excellent E70 DAC featuring the new AK4499EX high-end digital-to-analog conversion chip from AKM. For the rest, it takes the excellent technical basis of its elder brother, combining a careful design and high-end components for exceptional sound performance with smart and practical features, such as Bluetooth, a 12V trigger or an adaptable output level.
By buying this product you get 34 loyalty points
Reference : 17119
349,00 €tax incl.
290,83 € tax excl.
Last items in stock !
Shipping date: 02-07-2025.
Topping E70 Velvet
Topping E70 Velvet DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Argent
AKM AK4499EX DAC
The Topping E70 Velvet embeds within its digital/analog conversion stage the brand new DAC chip from AKM, the AK4499EX, the new flagship of the manufacturer. This converter benefits from a switched resistor architecture using the proprietary VelvetSound technology. It uses the latest high quality conversion technologies to provide the most vivid and realistic sound reproduction possible.
A state-of-the-art I/V conversion circuit
The E70 Velvet uses the excellent I/V conversion circuitry implemented by its big brother. It is designed to ensure low distortion and low noise, while taking up less space. It is here pushed to its limits to allow the DAC to reveal its full potential.
Bluetooth 5.1
Equipped with a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, the E70 Velvet lets you stream your music remotely directly from your smartphone or tablet. It also supports the high-resolution transmission codecs aptX, aptX HD, aptX Adaptive and LDAC, guaranteeing high-quality playback over Bluetooth. In addition, the E70 Velvet bypasses the conversion stage of the Bluetooth receiver to use the much more powerful AK4499EX DAC in order to provide the most faithful sound reproduction possible.
XMOS XU316 USB Interface
The USB input of the Topping E70 Velvet is associated with a latest generation XMOS XU316 interface with custom Thesycon driver. This powerful interface supports high resolution audio streams, up to PCM 32bit 768kHz and DSD512, for a very high quality listening.
Trigger 12V
The E70 Velvet features a 12V trigger with active (trigger output) and passive (trigger input) control. With only a single 3.5mm Jack cable, the E70 Topping can be switched on and off in sync with your other equipment with a 12V trigger interface.
Selectable output modes
The E70 Velvet provides balanced XLR and single-ended RCA output. The input is selectable and allows to activate only one or both simultaneously. Moreover, Topping offers a smart feature, allowing you to adjust the level of these outputs according to your use and the desired integration. Thus, the level of the XLR output can be changed from 4V to 5V and the RCA output from 2V to 2.5V.
1ON-OFF / input selection button
2Screen
3Volume button
4Coaxial input
5Bluetooth antenna connector
612V trigger input
7Balanced XLR output
8Single-ended RCA output
9Optical Toslink input
10USB-B input
1112V trigger output
12Power supply input
13Power button
Product typeDAC
InputsBluetooth 5.1
1x USB-B
1x Coaxial
1x Optical Toslink
1x Balanced stereo XLR
DAC chipAKM AK4499EX
Bluetooth receptionQCC5125
USB interfaceXMOS XU316
Supported Bluetooth codecsAAC
SBC
aptX
aptX HD
ptX LL
aptX Adaptive
LDAC
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Measurements
DAC E70 Velvet parameters (line out / USB input @ 96kHz)
RCAXLR
THD+N (A-Weighted)< 0.00008% @ 1kHz< 0.00006% @ 1kHz
THD @ 90kBw (Non-Weighted)< 0.0002% @ 20Hz-20kHz< 0.0002% @ 20Hz-20kHz
SNR (A-Weighted)125dB131dB
Dynamic range @ 1kHz, A-Weighted125dB131dB
Frequency response20Hz-40kHz (±0.3dB)
20Hz-40kHz (±1.0dB)
20Hz-40kHz (±0.2dB)
20Hz-40kHz (±0.8dB)
Output level2.1Vrms @ 0dBFS (Mode 4V)
2.5Vrms @ 0dBFS (Mode 5V)
4.2Vrms @ 0dBFS (Mode 4V)
Noise (A-Weighted)< 1.3µVrms< 1.3µVrms
Channel crosstalk-130dB @ 1kHz-143dB à 1kHz
Channel balance0.3dB0.3dB
Output impedance50Ω100Ω
ColorSilver
Dimensions (L*P*H)200*138*44mm
Package1x Topping E70
1x Remote control
1x USB cable
1x Power cable
1x Bluetooth antenna
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
Remote ControlYes
9 reviews
Amélioration et aération
J'étais en RCA avec un octavio stream g1 sur un marantz pm 6003 et une paire de dittons 442 recapé. Le son était bien mais depuis que j'ai mis le topping e70 velvet en action ( câble optique sur l'octavio et USB sur le pc ) le son est plus aéré et la scène sonore plus précise avec une meilleure séparation des instrus . Très content de mon achat . Prochain upgrade l'ampli pour aller chercher plus de chaleur et dynamique. Certainement un pm 8006 ou un marantz ki .
This review has been posted for TOPPING E70 VELVET DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Silver
Awesome!
Plently of technical reviews online (which also made me buy it), so in short:
- Great item with amazing sound
- Great price
- Great service with fast shipping
JUSTE EXCELLENT
Rien a ajouter sauf que si vous recherchez une restitution naturelle alors prenez celui-ci, vous ne pouvez pas vous tromper.
NB: reçu très rapidement après ma commande, je salue AUDIOPHONICS pour sa réactivité, merci beaucoup.
Bien
Reproduction en dynamique, peux être trop ?
Il y aura trop de bass pour certains, fonctionne mieux avec mon marantz 8000 qu'avec mon nad 352 "vintage"
Je conseille pour ceux qui aiment le rythme où même pourquoi pas un dj, il bouge quand même pas mal.
J'aurais aimé des horloges plus haut de gamme et des op-amp dédié pour le velours.
Bref tu en a pour ton argent mais ce n'est pas parfait
Excellent VALUE (SOUND) for the money (Topping E70V)
I bought this DAC in Dezember 2024 at AUDIOPHONIC.
PROS:
Excellent packaging and fast delivery.
Unboxing:
Due to low outside temperature, I waited for the unboxing 24 h after delivery (problem is condensation of cold equipment in warm rooms: ) Then everthing was all right as reported in the packing list.
Installation:
I use a DAPHILE SW with(old WIN7 labtop PC with I7 processor and 12 GB RAM and new installed SD-harddisc since 2021.
I use the DAPHILE upsampling process 44/16 to 192/24 with internal volume control. So i am able to control the SW via a LENOVO tablet (2 applications have to run at the same time on the tablet (DAPHILE in Browser to select playlist and PLAY-FROM-RAM-Mode and SQUEEZER for volume control.
Easy Plug-and-Play with DAPHILE. No driver needed.
I use chinch output of the DAC , which have to be selected with remote control (RC).
The delivered USB-cable is a little bit stiff, but sounds better then old USB-cable of Pro-Ject DAC DS even in 192/24 mode. I was suprised.
Filter options (PCM-mode) after testing i fixed F-4 as best.
SOUND impressions: (after one week of intensive checks)
I'm using electrostatic loudspeakers ES300 and DIY dipol bass in my special symmetic layouted listening room:
- strong low bass - very controlled much better then before
- upper bass - more controlled
- mids - charming voices, focused in the center.
- soundstage - very deep and wide impression,
- hights - awesome bells and pecussions, very airy.
Never heared DOORS-Raiders on the Storm with such emotions.
Others:
Bluetooth is working with my smartphone, but not important for me.
Both Digital Inputs have'nt been tested - no use.
CONTS:
No battery for the remote control supplied. (2x AAA)
Conclusion:
May be there is a better DAC available, but for me the measured specifications and the sound are excellent.
Before I read a lot of reviews in the internet.
Now I have choosen the best choice with the TOPPING DAC E70Velvet.
I recommend this DAC for AUDIOPHILES,
With the E70 Velvet, Topping offers a new version of the excellent E70 DAC featuring the new AK4499EX high-end digital-to-analog conversion chip...
