This 32bit 384Khz DAC offers the latest generation of ESS SABRE ES9028 PRo chips with true balanced outputs and a powerful adjustable digital volume level. Of a high quality design with a powerful Amanero USB input, it offers a first-rate sound performance at a tight budget.
By buying this product you get 37 loyalty points
This DAC based on ES9028 Pro 32bit chips offers formidable performance at a reasonable budget. Equipped with a truly symmetrical DAC output scheme with two XLRs, it is possible to control, for example, a pair of active studio speakers or a power amplifier thanks to the ESS SABRE volume, the best digital volume on the market.
Its Amanero dual clock USB input with galvanic isolation is most powerful using a programmable FPGA and not a chip already integrated. Using a TCXO 100Mhz clock of 0.1PPM with its own dedicated regulation this DAC offers a great precision coupled with an exceptional musicality in a contained budget.
The analog outputs are really balanced since the conversion and respect the ESS specifications with a "Quad differential" scheme allowing a great dynamics, a great background noise reduction. All 6 LM49990 PDOs on the circuit are on interchangeable DIP 8 holders, allowing the PDOs to be changed for more efficient models at will. In addition, the power supply has 10 LDO regulations and low noise subgroups guaranteeing a high purity signal even on small details and harmonics.
This audio converter features only quality components with Wima, Elna, Panasonic capacitors, shielded transformer, fast diodes and metal to film resistors.
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | ES9028PRO |
| Max sampling rate | 384kHz |
| Color | Silver |
Drivers AMANERO Vista WIN 7 / WIN 7 / WIN 8 32bit 64bit 64bit
Download (1.48M)
