AUDIO-GD MASTER 7 SINGULARITY Balanced DAC 8x PCM1704UK I2S AMANERO
The MASTER-7, excellent DAC Symmetrical from Audio-GD returns in Singularity version with I2S and USB Amanero
KEY POINTS:
  • 8x DAC PCM1704UK
  • I2S via RJ45 or USB
  • USB Amanero
  • DSP V7 + NOS Mode
  • 32bits 384kHz
By buying this product you get 264 loyalty points
Reference : 11630
2 649,00 €tax incl.
2 207,50 € tax excl.
Limited Edition PCM1704
DAC Symmetric / 8x PCM1704UK / DSP / AMANEROK Audio-GD MASTER-7 Singularity
A DAC DSP out of the ordinary ...
The MASTER 7 SINGULARITY (Limited Edition!) Is now back in the flagship of the Audio-GD converters and is now enhanced with its DSP V7 and the addition of 2 Xilinx CPLDs dedicated to the management of asynchronous transfers. record sampling rates: up to 32 bit / 384kHz.
Equipmwith the latest AMANERO Asynchronous USB interface in an enhanced version by Audio-GD, this converter is pruned for the future, with Mr. Kingwa giving way to a programmable version of the software. This in the future improves the product and its performance without affecting the hardware, but only to the software.
DSP V7 3 Oversampling modes and a "NOS" mode
The new features include 3X, 4X (normal mode), 2X Oversampling modes and a NOS oversampling mode with the new fully programmable DSP V7 software supported by two high precision TCXO clocks for even lower jitter.
Specially provided interior
The integrated PCM1704UK converters allow you to manage sources up to 32Bit / 384kHz. The MASTER 7 SINGULARITY has 6 inputs: BNC SPDIF, 2x Coaxial SPDIF, Optical Toslink, and I2S via RJ45 or USB, as well as 3 outputs: RCA, ACSS, and XLR. That is, the entire internal wiring is designed in OCC Copper, and two TCXO Audio-GD Clocks are directly integrated, allowing the Jitter to significantly decrease.
Audio-GD Master-7 Singularity
An extraordinary architecture
32bit / 384kHz / I2S / TCXO / USB AMANERO
Its architecture with built-in DSP is associated with a separate power supply of 21 groups, including 19 in Class A high-flying. Its transformers develop up to 1500W of power, for only 48W of consumption. All the components are sorted on the shutter and paired by hand: very high fidelity in fact.
The MASTER 7 SINGULARITY is therefore designed around 8 PCM1704UK and DSP1 (Altera Cyclone II) which work in parallel, alongside ultra discrete AOP. A 100% black anodized aluminum structure completes this sober and elegant architecture, which leaves transpunleash all its power.
DSP Altera Cyclone 2
DSP - Altera Cyclone II
The French definition of DSP would call it "Digital Signal Process", or "Digital Signal Processing". This mini processor is optimized to process a large amount of data in parallel with each clock cycle. It is very efficient to process the digital signals that arrive to it. The Altera Cyclone II makes the MASTER 7 a very high fidelity device.
8x PCM1704UK
These 8 analog digital converters (DAC) use the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network constituted solely by resistors having a given value (R) and its double (2R), without going through an over-sampling phase.
Class A
SpecificationsTHD<0.0008% (20Hz - 20kHz)THD + N109 dB (22Hz - 22kHz)Frequency Response20Hz - 20kHz (-0.01dB)Output Level2.5V RCA / 5V XLR / 2 + 2mA ACSSOutput Impedance10ΩInput sensitivity0.5Vp-p (Coaxial, 75Ω) / 19dBm (Optical)Supported Operating Systems/ Windows (44.1kHz to 192kHz) / OSX (44.1Khz to 384kHz) / Linux (44.1kHz to 192kHz) / USB compatible iPhone and iPad via Apple Camera KitSupported sampling ratesI2S up to 384kHz / BNC and Optical up to 96kHz / Coaxial up to 192kHzVariousConsumption48WWeightAbout 15kgHousing material100% Aluminum<color/ Td>BlackDimensions430 x 430 x 93mmAccessoriesPower cable / USB cable
InputBNC
InputI2S via RJ45
OutputACSS
DAC / ADC ChipPCM1704UK
Max sampling rate384kHz
Enooooorme
Alors là, j'ai franchis un pas très significatif dans le plaisir d'écoute. Ce DAC est très précis, avec beaucoup de définition dans les cymbales, le grain de la peau d'une caisse claire sous les ballets, et plus généralement dans la partie haute du spectre. Les parts medium et basse ne sont pas en reste, avec des impacts précis, charnu, mais pas baveux.
This review has been posted for AUDIO-GD MASTER 7 SINGULARITY Balanced DAC 8x PCM1704UK I2S AMANERO
The MASTER-7, excellent DAC Symmetrical from Audio-GD returns in Singularity version with I2S and USB Amanero KEY POINTS: 8x DAC PCM1704UK...
