Beautiful sound, love it!
By buying this product you get 247 loyalty points
The Denafrips Pontus 15TH NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here, each channel is equipped with an independent high-speed FPGA to facilitate digital signal decoding by means of 4 sets of high-precision R-2R networks. The choice of such a design results in very low linearity error, high decoding speed and low digital noise, not only to ensure that the audio signal has very low distortion, but also to ensure very low background noise.
All digital inputs are buffered in FIFO memory and reclocked by integrated femtosecond oscillators. Excellent jitter rejection makes the Denafrips Pontus II 12Th-1 much less dependent on the quality of the source equipment's clock.
Points clés :
The Denafrips Pontus 15TH features a linear power supply stage specifically developed for this DAC and isolated by a 1.5mm-thick metal case to considerably limit interference.
Placed beneath the DAC board, this power supply circuit embeds two large 80VA O-Core transformers for the digital and analog sections, low ESR capacitors and a super-linear linear power supply to provide the conversion stage with a clean, stable electrical signal.
The Denafrips Pontus 15TH features comprehensive connectivity for easy integration into the vast majority of audio systems. Inputs include USB-B, I2S via HDMI, Toslink optical, AES/EBU and coaxial. On the output side, the DAC provides unbalanced RCA and balanced XLR.
| 1 | Balanced XLR output |
| 2 | Single-ended RCA output |
| 3 | Coaxial input (RCA) |
| 4 | Coaxial input (BNC) |
| 5 / 6 | AES/EBU input |
| 7 | Optical input |
| 8 | I2S input via HDMI |
| 9 | USB-B input |
| 10 | Power connector |
| Specifications | |
| Product type | Balmanced NOS R2R DAC |
| Inputs | 1x USB-B 1x I2S via HDMI 1x Optical Toslink 2x AES/EBU 1x Coaxial BNC 1x Coaxial RCA |
| Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
| Supported sampling rates | USB / I2S : PCM up to 24bit 1536kHz, DSD up to DSD1024 Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP64 |
| Output level / impedance | 2Vrms @ 625 Ohm 4Vrms @ 1250 Ohm |
| Sampling modes | Non-oversampling (NOS) Oversampling (OS) |
| Frequency response | 20Hz - 70kHz (-3dB) |
| THD+N | 0.0025% |
| SNR | 120dB |
| Dynamic range | > 121dB |
| Crosstalk | -110dB |
| General | |
| Supply voltage | 100-240VAC 50/60Hz |
| Consumption | <= 20W |
| Color | Silver |
| Dimensions | 320 x 330 x 80mm |
| Weight | 12.5kg |
| Package | 1x Denafrips Pontus 15TH Silver (Power cord not included) |
| Input | I2S via HDMI |
| Input | USB |
| Input | Optical |
| Input | AES/EBU |
| Input | SPDIF |
| Output | RCA |
| Output | XLR |
| DAC / ADC Chip | R2R LADDER DAC |
| Max sampling rate | DSD1024 |
| Max sampling rate | 1536kHz |
| Color | Silver |
| Networking | No |
| Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
